Splinter back side of the wood
Forum topic by Steven H posted 03-10-2010 03:53 AM 1077 views 0 times favorited 4 replies Add to Favorites Watch
View Steven H's profile
Steven H
1117 posts in 3056 days
03-10-2010 03:53 AM
I’m using Titanium Nitride Twist Drill Bit to drill all the way through wood, every time I do that it cause splinter on the other side, is their a way to prevent this?
Thanks
27250 posts in 3817 days
#1 posted 03-10-2010 03:55 AM
One way to prevent this, Steven, is to clamp a backer board behind the wood. This should prevent splintering.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3476 days
#2 posted 03-10-2010 05:36 AM
Another idea is to drill a very small hole all the way through first, then drill your hole half way through with a bradpoint bit. Flip the piece over and drill again from the other side.
-- Wayne - Plymouth MN
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3282 days
#3 posted 03-10-2010 09:24 PM
Scott and Wayne are both right. I use the back up board more often because it’s usually easier. I don’t always clamp it, but it must be firm against the workpiece.
-- http://shepherdtoolandsupply.com/
View Alonso's profile
Alonso
949 posts in 3234 days
#4 posted 03-10-2010 09:42 PM
I got a huge improvement on the drilled holes just by working with Brad point drill bits, I got to say that the back up board its a great idea, but also the Brad point drills wil prevents skating.
-- The things I make may be for others, but how I make them is for me.
