Band saw burning on one side of cut
Forum topic by kevinw posted 03-09-2010 08:22 PM 1883 views 0 times favorited 5 replies Add to Favorites Watch
View kevinw's profile
kevinw
191 posts in 3645 days
03-09-2010 08:22 PM
Topic tags/keywords: bandsaw burning
Any ideas how to solve this problem? Bandsaw used to work well, but lately I get burning on one side of the cut only. Changing the blade does not help. The tires on the wheels are fairly new. Nothing seems to wobble or be particularly noisy. It is a pretty good quality Delta saw. Probably 15-20 years old.
-- Kevin, Blue Springs, MO
5 replies so far
View Eli's profile
Eli
141 posts in 2912 days
#1 posted 03-09-2010 08:40 PM
Are the guide wheels/blocks out of alignment? They might be rubbing on that side of the blade. That doesn’t really make any sense but I thought I’d give it a shot. If mine were doing that, I’d assume I was doing something wrong.
Eli
View Alex Lane's profile
Alex Lane
461 posts in 3796 days
#2 posted 03-09-2010 08:45 PM
I’d suggest looking at the tensioning system. If the tension spring is wearing out, you may be lacking enough blade tension, causing the blade to slightly bow during the cut, and thus burning only one side. See my fiasco with blade tension here.
highlandwoodworking.com has a replacement spring made by Iturra that should work for your saw.
I hope this helps!!
-- Lane Custom Guitars and Basses
View Walnut_Weasel's profile
Walnut_Weasel
360 posts in 3128 days
#3 posted 03-09-2010 09:43 PM
(Newbie here, watch out!) I am just stabbing at air here… Is it a new blade and does it cut straight? Perhaps the tooth set on one side is not correct causing the chips to become trapped on that side only? If it is an older blade do you have rust building up on one side only?
I would be interested to find out what is causing this in case I run into it in the future! =)
-- James - www.walnutweasel.wordpress.com
View Mario's profile
Mario
902 posts in 3957 days
#4 posted 03-09-2010 09:48 PM
It also sounds like you might be fighting against the drift of the blade and the back of the blade is burning the wood.
-- Hope Never fails
kevinw
#5 posted 03-13-2010 05:08 PM
Thanks for the tips. Been snowed this week so haven’t been able to test much. I did adjust the guide blocks some and did a cut on a small piece freehand and it seemed like it might be better. Real test will be to saw something substantial which I haven’t done yet!
