Help--Table Saw Arbor Moved?
Forum topic by jayseedub posted 03-26-2016 09:25 PM 772 views 0 times favorited 3 replies Add to Favorites Watch
View jayseedub's profile
jayseedub
127 posts in 1959 days
03-26-2016 09:25 PM
Topic tags/keywords: arbor table saw ridgid ts2412 adjustment tablesaw rigid 2312 help
I just removed my dado blade, and tried to install my normal blade—and the arbor nut won’t cinch tight against the blade—there’s at least a 1/16 of space between the blade and nut. Of course, the blade then wobbles, and isn’t tight.
Might I have pulled the arbor out by 1/16 or 1/8 when I snugged up my dado blade?
What do I do? Do I have to disassemble the whole arbor assembly and re-adjust it, or is there a way to knock it into place?
I have a Ridgid TS2412, FYI.
Desperate for your kind advice—thanks!
—jw
3 replies so far
View MrUnix's profile
MrUnix
6698 posts in 2193 days
#1 posted 03-26-2016 09:31 PM
Did you forget to put the washer on first?
jayseedub
#2 posted 03-26-2016 10:37 PM
Brad just might be THE man. After posting I looked at the manual, and did indeed see that there is supposed to be a washer/collar. Funny thing is, I can’t remember (I’m not THAT old) using that collar in the past years (but now that I see it, it sure does look familiar!).....
Pretty sure we can consider this resolved—now I’ll dig through my dust collection hose to see if the collar is in there! In case it’s not, it looks like it’s no longer available as a replacement part online, so I might need to get creative.
Thanks for the quick reply!
—jw
jayseedub
#3 posted 03-26-2016 11:05 PM
Brad is confirmed to be the man—I found the washer, hiding. Color me embarrassed…..
Good to know you folks are out there, though—with special thanks to MrUnix,
—jw
