tools for granite
Forum topic by stratiA posted 03-09-2010 04:00 PM 1316 views 0 times favorited 6 replies Add to Favorites Watch
View stratiA's profile
stratiA
101 posts in 3614 days
03-09-2010 04:00 PM
Topic tags/keywords: granite
Hi everyone.
I have come across a few granite scraps that I want to incorporate into some wood working projects. Most of the larger pieces are jagged broken slab pieces 1.5” thick. I am trying to figure how to cut them. I was going to use a cir saw with a stone cutting blade. But will it cut something that thick. I have access to a grinder. However I have doubts that I could cut straight line with it. Any advice would be appreciated it regards to cutting, edge shaping, and polishing is appreciated. I have seen some some of the vids on youtube. Some were helpful some not. Thanks.
-- Strati Alepidis, Burlington, Ma, Member Red Sox nation
View Don Butler's profile
Don Butler
1092 posts in 3633 days
#1 posted 03-09-2010 04:11 PM
You need diamond tools to cut granite.
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
View Gene Howe's profile (online now)
Gene Howe
11148 posts in 3666 days
#2 posted 03-09-2010 04:41 PM
Rent a saw similar to this one with a 10” diamond blade.
http://www.amazon.com/gp/customer-media/product-gallery/B000J0BG7W/ref=cm_ciu_pdp_images_0?ie=UTF8&index=0
View dannymac's profile
dannymac
144 posts in 3254 days
#3 posted 03-09-2010 05:26 PM
use a daimond blade, make multible shallow cuts no more than a 1/4” at a time. try to keep the stone and the blade wet, if ya need to try to get someone to help you by keeping a steady stream of ware flowing over the stone while you make the cuts.
by the way dud I’m right done the street.
-- dannymac
View John Ormsby's profile
John Ormsby
1288 posts in 3975 days
#4 posted 03-09-2010 05:31 PM
You will need a respirator to cut granite or other stone dry. Lots of silica dust. A wet diamond blade saw is the best way. I have a few different types of diamond saws. I also use a wet grinder/polisher for profiling and polishing the edges.
You can also check with a local granite countertop shop and see what they would charge to cut the slabs. Might be less expensive and give you better results.
-- Oldworld, Fair Oaks, Ca
dannymac
#5 posted 03-09-2010 05:52 PM
John just brought up a good point . If ya know where the Arsenal Mall is there are a couple of stone place nearby.
-- dannymac
View BradHess's profile
BradHess
63 posts in 3250 days
#6 posted 03-10-2010 07:19 AM
I just cut a slab for the desk that I built. See my profile. I was able to cut it with a circular saw and diamond blade taking very light passes and a straight edge guide. If you try to cut too much at once the blade will deflect and the cut will not be square.
