DIY Laminate Countertop?
Forum topic by clin posted 03-25-2016 10:21 PM 1243 views 1 time favorited 23 replies Add to Favorites Watch
View clin's profile
clin
841 posts in 994 days
03-25-2016 10:21 PM
I’m laminating my own countertop for my workshop. My question has to do with how to mount the backsplash. I’ve seen two methods described online.
One is the top is full width going back to the wall and the backsplash sits on top of the counter. Presumably screwed from below.
The other is the backsplash mounts to the back edge of the top with screws going in horizontally.
This second approach would seem stronger because the horizontal screws would be going into the built up 1 1/2” edge thickness of the top. Versus, screw up through the top into the 3/4” thick backsplash.
However, what I don’t like about attaching the backsplash to the edge of the top, is it is the backsplash that will be resting on the back of the cabinet. Therefore the back edge of the top is supported by the screws going through the backsplash. Of course the top is supported everywhere it crosses the sides of the various cabinet cases.
I doubt it really matters, but since the backsplash is laminated then attached, the joint is caulked, but not glued. If it were particle board glued to particle board, it would be very solid.
Just looking for opinions.
-- Clin
23 replies so far
View hotbyte's profile
hotbyte
991 posts in 2973 days
#1 posted 03-25-2016 10:58 PM
Is there a sink? If not, why a backsplash for workshop?
View clin's profile
clin
#2 posted 03-25-2016 11:15 PM
Yes, there is a sink.
-- Clin
View JBrow's profile
JBrow
1354 posts in 918 days
#3 posted 03-26-2016 01:23 AM
clin,
The one reason I can think of for mounting the backsplash on top of the countertop is protecting the back edge of the countertop from water. A ¾” backsplash will keep any water that strikes the backsplash and runs down the backsplash to the countertop ¾” from the back edge of the countertop. This second line of defense may offer a little more protection should the caulk fail. But since you are building this for your shop, I am sure you will be pretty careful with water around the sink – water is probably not going to set very long at the back edge. Therefore, it probably does not matter all that much which way you go.
There is a third mounting method. The backsplash could be mounted both on top of and against the back edge of the counter top at the same time. This would be done by rabbeting the backsplash. This method would allow the backsplash to be glued to the back edge of the countertop reinforced with screws.
hotbyte
#4 posted 03-26-2016 01:40 AM
Nice!
Could you pocket hole from back side of back splash?
- clin
View Ger21's profile
Ger21
1074 posts in 3129 days
#5 posted 03-26-2016 03:38 AM
Put a bead of silicone on the bottom of the splash, and a few dabs of construction adhesive on the back, and stick it in place. Cut a few stick of scrap wood sticks to wedge the splash tight to the counter, using the ceiling or wall cabinets for the sticks to push against.
Scrape up the excess silicone, and clean what’s left with lacquer thinner. When it’s dry, you’ll never be able to get it off.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View clin's profile
clin
#6 posted 03-26-2016 04:55 AM
clin,
- JBrow
Hadn’t thought about the straight down run of water off the backsplash. At least if the backsplash is mounted on top, the joint is horizontal and gravity isn’t trying to help. Though capillary action may make that a moot point either way.
Also, the backsplash would be mounted with caulk in the joint, not just added after the fact to the inside corner. I think the idea is to have this caulk ooze out and be the same caulk that the runs in the corner. With the backsplash screwed on, hard to see anyway that would ever fail and allow water down it.
And, it is a utility sink in a workshop. Might go days or even weeks at a time and not get used. Unlike a kitchen or bath where it is used multiple times daily.
- JBrow
I was thinking something similar. But rather than cutting rabbets, you could stagger the doubler on the back to create the effect of a rabbet cut in the top. though this still give you a vertical joint first, then horizontal.
Nice!
- hotbyte
Pockets holes is a darn good idea. The cases have about a million pocket screws already. What’s a few more. In then end, I’m not sure how much stronger it really will be. But if nothing else, the screw could be quite long and would go into the meat of the back edge of the top. Screw won’t pull out.
By the way, my concern for strength is really just until the thing gets mounted. Wouldn’t take much of a bump to cause a failure of material where a screw goes edgewise into a 3/4” piece of particle board.
Scrape up the excess silicone, and clean what s left with lacquer thinner. When it s dry, you ll never be able to get it off.
- Ger21
I agree another way to go. Though I do lean towards a more immediate an positive attachment.
All of these are fair points and ideas. In the end, my gut tells me, it just doesn’t matter. It’s just the engineer in me is always looking for the best way, even if another 10 ways are good enough.
I may also build up some test examples. May give me a better sense of how strong or weak a method is.
-- Clin
View dhazelton's profile
dhazelton
2767 posts in 2294 days
#7 posted 03-26-2016 12:07 PM
I’ve never seen one screwed in that I’ve ripped out. Always just siliconed in place.
View jbay's profile
jbay
2287 posts in 897 days
#8 posted 03-26-2016 02:10 PM
I always made mine 1 1/2” thick with a rabbet at the top so that it’s easy to scribe to the wall, because walls are never straight. I screw them on from the bottom after the top is attached.
I would also put about a 1 or 2 degree angle at the bottom so that when you screw it to the counter top the angle helps suck it tight against the wall. (Silicone or siliconized caulk on the edge first)
View chiseler's profile
chiseler
124 posts in 886 days
#9 posted 03-26-2016 11:17 PM
- Ger21
I have done it both ways,but found Gerry’s way the easiest,except I take it one step further,and put a 1/4” groove in the counter top,and a 1/4”x1/4”tongue on the splash just in case the top isn’t dead nuts flat/straight,and I have installed hundreds of counter tops over the years,and I’ve also found that phenoseal works best.It not only seals out the water when dry it’s also an adhesive that cleans up nicely with water while it’s still wet.If the wall is bad I’ll glue a strip of 1/4”x 3/4” strip of soft wood on the back of the splash before laminating(splash ends up 1”plus thick),and scribe it to the wall.
good luck Scott
-- Scott.Triangle,NY Becareful and don't forget...They cut meat too! Ask me how I know
Ger21
#10 posted 03-27-2016 12:16 AM
I meant to add that the shops I’ve worked at have made and installed thousands of backsplashes over the years, always with just silicone. Have never seen a failure.
View WesternRevival's profile
WesternRevival
10 posts in 1194 days
#11 posted 03-27-2016 12:20 AM
Half Lap joint. Glue and screw both horizontally and vertically.
-- Will, www.westernrevival.net
View AlaskaGuy's profile
AlaskaGuy
4135 posts in 2307 days
#12 posted 03-27-2016 12:31 AM
- Ger21
KIS +1
View jbay's profile
jbay
#13 posted 03-27-2016 12:37 AM
- Ger21
Works if it’s for yourself, but…
Does that mean an extra trip back to the customers to remove the scrap sticks?
Or do you ask the customer to finish the job for you?
chiseler
#14 posted 03-27-2016 03:39 AM
I meant to add that the shops I ve worked at have made and installed thousands of backsplashes over the years, always with just silicone. Have never seen a failure.
- Ger21
I’ve used silicone in the past,and the “only “reason I prefer phenoseal is because it’s easier to clean up than silicone,and in 38 years I’ve yet to see” it” fail.but you are right in saying silicone is a great adhesive,just a PITA to clean up oozage afterwards
View JackDuren's profile
JackDuren
388 posts in 957 days
#15 posted 03-27-2016 01:28 PM
- Ger21
This is the way most all commercial/residential shops install back splashes with the exception of a few using Smart Clips.
