Forum topic by Walnut_Weasel | posted 03-08-2010 05:36 PM | 3004 views | 0 times favorited | 4 replies | ![]() |
I have a few general questions for the Jocks about veneering and inlaying. I have begun making an end table and I was thinking about putting some inlay about an inch or so in from the outside edges of the top around all 4 sides. I am concerned that when running the strips across the grain that the inlays may crack/split. Is this something I should think about in the design of the top or will the glue allow for enough movement? What about with thicker “home-made” veneer that is 1/16”? If so could this be prevented using hide glue? The top of this table is only going to be about 20” square but what about larger tops for something like a kitchen table? -- James - www.walnutweasel.wordpress.com |
#1 posted 03-09-2010 02:40 AM |
The only safe way to do it would be to cross grain the inlay it’s self in those sections as well. That way, the inlay will move with the top. -- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle |
#2 posted 03-09-2010 03:07 AM |
inlay in a solid wood top is usually a bad idea. even if the top was ripped, jointed and glued back together in the same orientation, it would be better, as some of the stress is relieved. If you can make “home-made” veneer, why not do a veneered top. it is actually quite satisfying to have made the lumbercore material and crossbanded it yourself. you know it is flat and never going to move. which gives you many more options for veneer decoration. -- Junior -Quality is never an accident-it is the reward for the effort involved. |
#3 posted 03-09-2010 05:01 AM |
Ok… In my original post I kind of opted for the ‘better safe than sorry’ answer. Check out my blog…. There are a couple of inlays that travel across the grain in the landing, and in the first tread of the stair. The tread and landing are both 1 1/2” thick Santos Mahogany. BUT….the 1 1/2” is composed of two 3/4” layers EPOXIED with the grain of each layer running perpendicular to the other. The inlay itself is a full 3/8” thick (Curly Maple), and it’s EPOXIED in as well. Ive done it this way for quite a few years and never had issues yet. Here’s another example…. This inlay…there was actually two of them in the house…was done to hide another company’s shoddy work. They were glued up in the shop in one massive piece 3/4” thick…but again, in two layers 3/8” thick, all grain running perpendicular….and again, with Epoxy only. http://i720.photobucket.com/albums/ww202/Tony_S_photos/Franks009.jpg http://i720.photobucket.com/albums/ww202/Tony_S_photos/Franks010.jpg http://i720.photobucket.com/albums/ww202/Tony_S_photos/Franks011.jpg So…never say never, but understand it’s a WHOLE lot of work just for a simple inlay. I also agree with Junior….Veneer IS better (easier) but unfortunately Veneer doesn’t work very well on surfaces you walk on… -- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle |
#4 posted 03-09-2010 04:11 PM |
Wow! Nice work Tony! Thanks for the suggestions. I ran across an article last night that suggested breaking up the inlay into smaller segments to minimize the movement of each piece of the inlay. I was thinking I could divide the strip in half and put a small design of some sort in between to reduce the strips to less than 10” each. -- James - www.walnutweasel.wordpress.com |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2104 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4900 |
6691 |
28039 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6224 |
1387 |
Focus on the Workspace
2153 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8842 |
