Butterfly Keys
Forum topic by chrisstef posted 03-08-2010 05:04 PM 3602 views 2 times favorited 3 replies Add to Favorites Watch
View chrisstef's profile
chrisstef
17423 posts in 3029 days
03-08-2010 05:04 PM
LJer’s,
Im looking for a little help and advice on butterfly keys. Im in the planning phase of making a table for the wife. Im planning on using reclaimed oak at random widths for the table top and use reclaimed fir butterfy keys at the joints (maybe 3 keys per joint). Im fairly confident at my ability to make the actual keys themselves but i was curious as to how one would go about making the recesses that the keys will sit in. Im assuming a router. Thanks in advance for the help!
3 replies so far
View JAGWAH's profile
JAGWAH
929 posts in 3107 days
#1 posted 03-08-2010 05:18 PM
Consider this if the inlays are mostly decorative.
http://www.woodcraft.com/Search/Search.aspx?query=router%20inlay
Otherwise hand cut with backsaw and chisel if their through butterflies.
-- ~Just A Guy With A Hammer~
chrisstef
#2 posted 03-08-2010 05:25 PM
JAGWAH,
Thanks for the link. Yes they are going to be totally decorative. I would like to inlay them along the joints. I was reading that to make the actual keys themselves i can tilt the tablesaw to 15 degrees and cut all 4 sides then rip them down to size on the band saw. Once the keys are made id lay them on the table top and using a marking knife trace around them. Then using the old steady hand, rout out the mortise needed for the keys, or i suppose i could use a chisel.
View davidpettinger's profile
davidpettinger
661 posts in 3223 days
#3 posted 03-08-2010 05:31 PM
chrisstef,
Here is a web site that explains the procedure.
http://www.americanfurnituredsgn.com/Butterfly%20Inlays%20.htm
-- Methods are many,Principles are few.Methods change often,Principles never do.
