is 12% MC ok for turning a bowl?
Forum topic by martin007 posted 03-08-2010 04:50 PM 1210 views 0 times favorited 4 replies Add to Favorites Watch
View martin007's profile
martin007
142 posts in 3678 days
03-08-2010 04:50 PM
Hi All
I would like to turn a bowl out of a 12% MC cherry. It`s for a birthday present in 4 weeks.
Is it too wet, can it warp or crack afterwards?
thanks for comments or suggestions
Martin
-- Martin, Gatineau, Qu├ębec
View davidpettinger's profile
davidpettinger
661 posts in 3103 days
#1 posted 03-09-2010 01:47 AM
If you are worried about the bowl drying out after you turn it, seal the bowl with CA glue to hold its current moisture level. A lot of bowl turners use CA glue just for that purpose.
-- Methods are many,Principles are few.Methods change often,Principles never do.
View EricRFP's profile
EricRFP
106 posts in 2997 days
#2 posted 03-09-2010 04:29 AM
I would say no, I’ve turned lots of bowls with 12% MC.
Since there is someone on LJ’s that is bound to disagree, you could always bring the wood inside your house for two weeks then turn the bowl. MC problem solved. We are talking about 12% here, not green wood.
-- Eric, NorCal www.rocklinforestproducts.com
View Roper's profile
Roper
1384 posts in 3616 days
#3 posted 03-09-2010 04:44 AM
it really depends on where you are and where the bowl will be, out here in colorado 12% is still to wet for a finished turning, you can always rough turn it and finish it later or you can try drying it out in the microwave, i have had good luck with this method.
-- Roper - Master of sawdust- www.roperwoodturning.com
View John Ormsby's profile
John Ormsby
1283 posts in 3640 days
#4 posted 03-09-2010 04:50 AM
You might be able to do it if you use an alcohol drying technique for the rough turned bowl. It will depend on how thick it is when rough turned. It is possible.
Microwave drying as has already been stated could also work.
-- Oldworld, Fair Oaks, Ca
