| Forum topic by Jason Tetterton | posted 1171 days ago | 851 views | 0 times favorited | 10 replies | ![]() |
1171 days ago |
Topic tags/keywords: embed image onto wood engrave I have an electronic image (jpeg) that I would like to incorporate into a cutting board.. I’m basically going to make the cutting board and then I thought about printing this image and gluing it to the surface and then applying the finish.. not sure how this would work… maybe recess it somehow? I also thought about having someone engrave the image onto the board.. any ideas? Here is the image: I want to put it in the bottom right corner of the board, all suggestions welcomed! Thanks EDIT: Finished this project, http://lumberjocks.com/projects/29727 -- Jason, Central Virginia |
10 replies so far
#1 posted 1171 days ago |
Jason – generally the knives used on a cutting board eventually dig through the finish and down to the wood, so the finish has to be renewed from time to time. If your image is printed on the wood or printed on paper and applied to the wood, there is a good chance that it will get worn through. That being said, if you print on rice paper and wet-out the paper with the finish, it nearly disappears in the finish. Also, there are printable decals that can be applied to the wood and then finished over. Good luck! -- http://www.peteroxley.com -- http://north40studios.etsy.com -- |
#2 posted 1171 days ago |
Thanks for the replies. Peter, are you suggesting that printing on rice paper may work? Where do I find such a thing and will it feed into a standard inkjet? Kunk, Where do you go for engraving if you don’t own an engraver? Do places like Woodcraft offer such a service? I found a place called touchofwood.com but I’m not sure if I want to send the piece off. Thanks -- Jason, Central Virginia |
#3 posted 1171 days ago |
Some trophy places have laser engravers. Might try that. -- "The way to make a small fortune in woodworking- start with a large one" |
#4 posted 1171 days ago |
Jason, there should be a local laser engraver close to you, check in the yellow pages for a custom print and award business. Also you can check here for a printable decal “how-to”. -- A hammer dangling from a wall will bang and sound like work when the wind blows the right way. |
#5 posted 1171 days ago |
Thanks for the tips.. I found a guy that does laser engraving right in my town, emailed him the info for a quote :) -- Jason, Central Virginia |
#6 posted 1171 days ago |
I am interested in hearing responses on this also. I am not familiar with the rice paper, but I would guess that anything printed on an inkjet will bleed as soon as the finish hits it. Sounds like a mess. I did see a nice project that somebody had done where they had somehow adhered an old map looking thing to a board, and put a finish over the top. I have no idea how they did it. |
#7 posted 1171 days ago |
People print pics and adhere it to plywood to cut jig saw puzzles. They use 3M spray glue to attach it to the wood and then put triple glaze over it. I know you can’t use triple glaze, but my point is that pics can tolerate a coating and still look fine. Please show us your board when finished. -- Vicki on the Eastern Shore of MD |
#8 posted 1168 days ago |
You might try the high school. Lasers are pretty popular in most shop classes these days. My daughter engraved a rose into her cutting board last semester. There is also a trick I have heard of, you print the image with a laser printer, place the paper face down on your wood and apply acetone to the paper. The toner releases from the paper and is transferred to the wood. I am not sure how clean this process is, I have yet to try it… -- A thing of beauty is a joy forever... |
#9 posted 1168 days ago |
modgpoge i think it’s called, guy named stevinmarin introduced me to it on a vid of his called the magic disappering box he shows how he put stickers on a box and then put a finnish over it. you can also recess the pic and put a piece of acrylic over it and seal the edges with sylicone sealnt -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#10 posted 1158 days ago |
Finished this project, check it out! http://lumberjocks.com/projects/29727 -- Jason, Central Virginia |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15785 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
