Price and Quality Check Table Saw Used
Forum topic by Benzene posted 03-24-2016 02:20 PM 780 views 0 times favorited 6 replies Add to Favorites Watch
View Benzene's profile
Benzene
1 post in 699 days
03-24-2016 02:20 PM
Topic tags/keywords: table saw cabinet saw used price quality
Hi Everyone,
New here, I’ve been doing wood working as a light hobby for a number of years now. I sold my old table saw when I moved, a little contractors saw that gave me a real hard time.
I want a full fledged cabinet saw, as I have some projects lined up which will require a bit more umph.
Can anyone vett out a Delta X5 I’ve been looking at? Price is 1400, which seems like it might be a bit high, but I wanted some opinions.
Delta X5
I haven’t contacted yet but I’ve also been looking at this grizzly, a 5959 which is 12’’ and 5hp, priced at 1000
Grizz G5959
Thanks!
View toolie's profile
toolie
2106 posts in 2534 days
#1 posted 03-24-2016 04:39 PM
The delta, hands down. its left tilt, has the 60” sliding miter table, has what looks like a Biesmeyer fence, is 5hp and its single phase! i love my two 10” CI contractor saws, but if that were closer to me, i’d make and offer and sell the two saws i now own. always try for a better price, but if its a solid machine, anything between $1K and the asking price is a good deal.
View generic's profile
generic
105 posts in 1504 days
#2 posted 03-24-2016 05:29 PM
If they are close by, I would look at both of them and see what shape they are in. The sliding table might be nice, but typically you see those in more of a production setting.
I would also consider what you will be using it for. A sliding table may be nice, but it could also a pain having to walk/work around all the time. A 12” saw will allow deeper cuts. I doubt you will ever have an issue with power seeing both are 5hp saws.
A couple years ago I picked up a Grizzly G7209. One of the things I love the most about it is the table size. It makes 10” cabinet saws look tiny. I believe that the G5959 has a smaller top than the G7209, but it may still be larger than a 10” saw.
I believe the G5959 also has a removable arbor extension that allows you to swap out extensions and use standard 8” or 10” blades for things like dado stacks.
I love my G7209. It is the best thing I have bought so far. Even better than the helix head I bought for my jointer. even with a 14” blade and cutting old oak, it have never lacked for power. The fence is great too.
With regards to price, I think it is a little high. that is what I paid for my G7209 and it was practically like new.
View Vern Little's profile
Vern Little
103 posts in 3442 days
#3 posted 03-24-2016 07:20 PM
I’d jump all over the Delta. I bought a used Unisaw 2 years ago and wondered how I made do with my old B & D.
It is so smooth you can stand a nickel on edge and start it and the coin still stands.
-- Earth first, we'll drill the rest of the planets later. Vern
View Julian's profile
Julian
1268 posts in 2596 days
#4 posted 03-25-2016 03:25 AM
Only way to decide is to go and look at them both. A 5hp table saw will probably be the last saw you will every need to buy.
-- Julian
View unbob's profile
unbob
801 posts in 1809 days
#5 posted 03-25-2016 04:13 AM
The Grizzly is a full size saw, the table and wings are 38”X48”, and uses 12” blades with 1” arbor, however the saws arbors are changeable to 5/8” for 10” blades. The left blade tilt on the Delta is a hindrance with the sliding table attachment “blade tilts into the slider fence”.
Be aware, the sliding attachment requires a huge amount of room on the left side of the saw. My set up is a right tilt 12” Delta with the same slider attachment, works pretty good.
View knotscott's profile
knotscott
7873 posts in 3281 days
#6 posted 03-25-2016 11:16 AM
The Delta’s got better heritage and better resale, but the Grizzly is a bigger saw. Go take a look at both and see what you like. The crosscut sled is cool if you have the space and a use for one….could be in the way for a lot of us. An offer can’t hurt. At $1400 you’re close to the price of a brand new G1023RL….not saying it’s robust as the Uni, but it’s a good saw for a hobbyist with a warranty, modern riving knife, etc.
