how to cut oval panel 3" smaller than tabletop??
Forum topic by Scott Gilroy posted 03-08-2010 05:03 AM 954 views 0 times favorited 4 replies Add to Favorites Watch
View Scott Gilroy's profile
Scott Gilroy
45 posts in 3026 days
03-08-2010 05:03 AM
I need to cut an oval panel that is 3” smaller than my existing oval table top. any suggestions for doing this? it needs to match the tabletop, just 3” smaller all around.
thanks for the input.
-- Scott
teenagewoodworker
2727 posts in 3793 days
#1 posted 03-08-2010 05:14 AM
either make a template of the existing table top and use a router and combination of a flush trim and rabbeting bit to take the 3 inches away (the router bits keep it all in line). or make the template and wrap a piece of thin wood around it so that you can index off of it. then use a wheel that had the same radius as the reduction you want and trace around the inside and then cut it out and everything. wheels are the key to keeping it all right and everything.
View woodworm's profile
woodworm
14468 posts in 3615 days
#2 posted 03-08-2010 05:16 AM
You need simple jig. Attach a pin or small bearing as an edge guide on the bottom of router sub-base just 3” away of the center of you router less the diameter of the bit. Use your existing table (if possible) as the the template and cut the new table top.
-- masrol, kuala lumpur, MY.
woodworm
#3 posted 03-08-2010 05:24 AM
I think Ryobi Router has this wheel (bearing) type of edge guide that can be mounted to straight edge guide fence.
View BTKS's profile
BTKS
1986 posts in 3489 days
#4 posted 03-09-2010 05:15 AM
Outline the table on luan or masonite, set scribe to 1 1/2 inches, redraw the perimeter from the template minus the 1 1/2 in and you’ve got the same shape, 3 in smaller. Now a flush trim bit or a straight bit and bushing will cut a new top. Best of luck, hope this helps, BTKS
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
