Help! - Restoration Project
Forum topic by bookworm posted 03-08-2010 04:26 AM 966 views 0 times favorited 4 replies Add to Favorites Watch
View bookworm's profile
bookworm
39 posts in 3563 days
03-08-2010 04:26 AM
Topic tags/keywords: question pine maple refurbishing joining
I could use some advice. I have a little restoration project and I’m not sure how to proceed. My wife and I are expecting our first child in June. Her parents gave us a small crib they had used for my wife and her siblings; so it is a bit of an heirloom. When we received it, the crib had been painted white and we decided to sand it down and repaint it. So far, so good. When I started to sand it down to bare wood, we found out it was made of maple! Painting immediately flew out of my head.
After working on it for half of a day, I discovered a problem. At some point, one of the legs had been replaced with a piece of southern yellow pine. I can make a new leg out of maple with little problem. The real issue is what is the best way to remove the pine leg? It appears to be just two mortise and tenon joints glued in place (NOT through tenons unfortunately).
I’ve considered two options. 1) Cutting the leg off flush at the joints and using either pegs or floating tenons to join the new leg on. 2) Cutting the pine leg off above and below the joints and making tenons out of the remaining pine material. Ideally, I’d rather find a way to deactivate the glue (I assume it is early 1980’s era yellow glue) and use the original tenon.
Any suggestions are greatly appreciated.
Thanks,
Doug
-- "I asked my wife if I look dorky in the video below where I'm planing that long piece of wood. Her reply: "It's all dorky."" - Mitch Roberson from his blog Furnitude
View alby's profile
alby
8 posts in 3310 days
#1 posted 03-08-2010 04:33 AM
You could try heat. A lot of glues will soften when heated. If it is white glue try hot steam. Just don’t over do it.
Alby….Canada
View rustfever's profile
rustfever
763 posts in 3552 days
#2 posted 03-08-2010 04:54 AM
Replacing is fine. However it is an heirloom. Even in it’s repaired condition, it is still and heirloom. Honor and cherish the past.
Ira
-- Rustfever, Central California
View davidpettinger's profile
davidpettinger
661 posts in 3442 days
#3 posted 03-08-2010 04:03 PM
Yea, like alby said, I would try heat to soften the glue and take apart the joint.
-- Methods are many,Principles are few.Methods change often,Principles never do.
bookworm
#4 posted 03-08-2010 05:17 PM
Thanks for the suggestions. I’ll give the heat a try.
Doug
