Jointer kickback?
Forum topic by trevor7428 posted 03-23-2016 04:32 PM 1498 views 0 times favorited 28 replies Add to Favorites Watch
View trevor7428's profile
trevor7428
237 posts in 833 days
03-23-2016 04:32 PM
So I just purchased my first jointer. Jet 6in.
I’m just wondering is it possible to get back on a jointer, if so how? Have any have or have-not had kickback with your jointer?
-- Thank You Trevor OBrion
28 replies so far
View KYSean's profile
KYSean
119 posts in 3469 days
#1 posted 03-23-2016 04:41 PM
Only by feeding it with no down pressure at all.
-- http://editedwrite.com
View CB_Cohick's profile
CB_Cohick
483 posts in 1124 days
#2 posted 03-23-2016 04:46 PM
I have not had it happen, but feeding against the grain, and as KYSean suggests not keeping enough downward pressure on the workpiece could lead to kickback.
-- Chris - Would work, but I'm too busy reading about woodwork.
View AZWoody's profile
AZWoody
1194 posts in 1097 days
#3 posted 03-23-2016 04:50 PM
Also trying to take too much a bite can increase the risk as well.
View nerdbot's profile
nerdbot
97 posts in 1234 days
#4 posted 03-23-2016 04:50 PM
I had kickback by having too much downward pressure and not feed forward properly. The push pads that came with my (used) jointer had no grip at all, so I had to put significant downward pressure and it was very difficult to push forward. That’s when I experienced a little kickback – though it was more like gouging than kickback. Using proper push pads (on a properly tuned jointer) where I only need minimal downward pressure, I’ve had no problems.
View cdaniels's profile
cdaniels
1320 posts in 1374 days
#5 posted 03-23-2016 04:58 PM
I’ll put myself out there as an ameteur, I was squaring up a 6” block on my jointer one day and didn’t realize that I had the endgrain pointed down. tried running that through and felt like it bout snapped my arm in half. Obvious mistake but I think it counts!
-- Jesus was a carpenter... I'm just saying
View pmayer's profile
pmayer
1015 posts in 2938 days
#6 posted 03-23-2016 05:14 PM
If the work piece is too short this can definitely happen. Anything shorter than 12” becomes risky.
View conifur's profile
conifur
955 posts in 1024 days
#7 posted 03-23-2016 05:22 PM
Why would that make a difference all else being equal?
View CharlesA's profile
CharlesA
3302 posts in 1670 days
#8 posted 03-23-2016 05:23 PM
- AZWoody
I thought this too until I started using my jointer for making tapered legs, taking 3/8” off in each pass. It works remarkably well, although I’m always nervous when I do it. I have found that the Grr-Ripp Blocks give me a lot more control.
View Pezking7p's profile
Pezking7p
3217 posts in 1524 days
#9 posted 03-23-2016 05:28 PM
- conifur
Because the cutter head area is open and the piece does not get the support it needs. You end up just feeding the piece downwards into the cutter head and it does not like that.
-- -Dan
nerdbot
#10 posted 03-23-2016 06:25 PM
- pmayer
Yeah, I think that was my other problem with my first use. I was just running test pieces and they were pretty short, shy of a foot if I recall correctly.
trevor7428
#11 posted 03-23-2016 07:04 PM
- conifur
- Pezking7p
Even if you start with pressure on right hand down (just at first) with no downward pressure with left hand (infeed side only) then once the short piece gets to the outfeed table, switch with all the pressure with left hand on outfeed table and only use right to push.
Would this still be feeding the piece downwards into the cutter head?
(I don’t really understand why you can’t run shorter than 12” either) just no you shouldn’t do it, but I want to know can it be done… safely?
conifur
#12 posted 03-23-2016 07:07 PM
I have run as short as 8”, just have to make sure it stays flat on the tables.
pmayer
#13 posted 03-23-2016 08:10 PM
The actual safe stock length for a given jointer depends on the size of the opening for the cutterhead. It’s really just a matter of having enough length of board supported by the infeed table to keep the board stabilized. As the bed surface that is supporting the work piece becomes shorter, the percentage of board that is over the cutterhead increases compared to that which is supported by the table. The shorter the board, the higher percentage you have “resting” on the cutterhead, and the more tippy the board becomes. That’s when it tips into the cutterhead it kicks back.
An experienced user, if paying close attention, can probably joint 8” stock without incident “most of the time”, but the chances of a kickback are still much higher than with a 12”+ board. I’ve occasionally jointed stock that short, but I would not advise someone who is just learning to attempt it. When I have to joint a shorter piece of stock, I pull out a hand plane. You can joint an 8” board pretty easily, even with a #4 plane.
View teejk02's profile
teejk02
479 posts in 998 days
#14 posted 03-23-2016 09:00 PM
Short pieces can be done with push-pads…just plan on getting the shallowest cut you can get and repeat (and repeat). Biggest drawback is the tendency to “taper” the board but with shallow passes I’ve never seen a problem with flipping the board head to tail. On my Delta 6” I learned to do that same thing even on longer stock once the really cupped surface is removed. And another thing…keep your tables and fence “slick” (I use Johnson’s paste wax)...”drag” is a safety hazard I think.
View Deaner's profile
Deaner
42 posts in 1959 days
#15 posted 03-23-2016 09:16 PM
3/8’s of an inch Charles…on each pass?? I can’t imagine. Not being critical, just awed:)
Having the sharpest knives possible helps…that and shallow passes. I try to keep my depth around 3/16’s if I have a flat enough board to catch the whole surface, and allow a little extra time for the added passes.
I might try a 3/8” pass tonight, if I can muster the nerve. I’m sure the machine has to be a bit bigger with more HP.
-- Once harm is done, even a fool understands it.
showing 1 through 15 of 28 replies
