New woodworker... Band Saw motor replacement question - AC to DC?
Forum topic by 13o13 posted 03-23-2016 04:16 PM 703 views 0 times favorited 6 replies Add to Favorites Watch
View 13o13's profile
13o13
5 posts in 763 days
03-23-2016 04:16 PM
New guy here… moving from lurking/learning to my first post!
I am very new to woodworking, and have recently acquired a 10” Rockwell 28-113 BS for a very low price. In addition to the 3/8 blade, it also came with a brand new Olson 1/2” blade. It’s powered by a 1/3 HP motor. I’ve had a lot of fun learning on it, and of course am now wishing for a much larger BS.
A couple of weekends ago, at an estate sale, I picked up a few decent size osage orange logs. They are quite old/seasoned. Everything that I’ve read about resawing recommends having, in addition to a bigger BS, which, sadly, is not an option for me right now, at least a 1 HP motor to handle bigger/more dense wood.
I have a line on a 1 HP, 10amp/90 volt DC motor, for a reasonable price. I have read on various forums that DC motors and an electronic speed controller are great for converting a wood BS to a metal BS. I have zero interest in using my BS to cut metal, therefore reducing the speed is not an issue for me.
My question is simple… hopefully the answer is, too. Will I be able to simply swap the 1/3 HP AC motor with the 1 HP DC motor, or are there additional steps or equipment I would need to take care of, as well?
Any help/insight you all can provide is greatly appreciated!
-Bob
View knotscott's profile
knotscott
7982 posts in 3344 days
#1 posted 03-23-2016 04:19 PM
I’m not an electrician or an EE, but AFAIK you’ll need to add a rectifier (or some way) to switch AC from the wall to DC.
13o13
5 posts in 763 days
#2 posted 03-23-2016 05:24 PM
...that’s the simple answer I was hoping for. Thanks so much!
View MrUnix's profile
MrUnix
6608 posts in 2167 days
#3 posted 03-23-2016 05:38 PM
Just as a reference, the manual for a 14” Delta recommends a 1/3hp motor for normal use, and a 1/2hp motor for heavy duty use or thick resaws with a riser block. As long as your blade is sharp, you can resaw almost anything, although perhaps not as fast.
That said, why buy a DC motor when you can get one for free or really, really cheap? Find a used treadmill on CL, and it will have pretty much everything you need – motor, power supply, speed control, wiring, etc… and they are typically around 2hp +/-:
I’ve found 4 for free in the last year or so, and in addition to the motor stuff, you get a ton of extra goodies as well, such as all kinds of hardware, bearing mounted rollers, stepper motor, material suitable for use as a router table top, and on and on….
View ChrisK's profile
ChrisK
1946 posts in 3050 days
#4 posted 03-23-2016 05:52 PM
Not sure how the connects to the wheel that drives the blade, but a 1 HP should have a bigger diameter shaft and you will need to adapt something for it to fit.
-- Chris K
13o13
5 posts in 763 days
#5 posted 03-23-2016 08:11 PM
I was hoping for 3/4 or more horses… I’ll expand my search to include 1/2. Should make it easier, and less $$.
Good tip… I’ll keep that in mind, as well.
- ChrisK
The 1 HP DC motor I referenced above has a 5/8” shaft, which is the same size as the 1/3 HP motor I currently use. If it was different size, an appropriately sized motor pulley isn’t that difficult to acquire.
View bbasiaga's profile
bbasiaga
1202 posts in 1963 days
#6 posted 03-23-2016 10:04 PM
If you have any mechanical engineering saavy friends, you may ask the to look at the rest of the drive train and see if it can handle 3x the power. If its belt driven you may be OK as the belt might just slip. But there could be a scenario where you push the wood harder/faster, the motor is trying to push more HP to make the cut, and the weak point gives.
Kinda like how you have to beef up the clutch plates on a car when you install certain turbo or supercharger kits.
-Brian
