Work bench top?
« back to Joinery forum
Forum topic by alittleoff posted 03-23-2016 02:38 PM 742 views 0 times favorited 4 replies Add to Favorites Watch
View alittleoff's profile
539 posts in 1211 days
03-23-2016 02:38 PM
I’m building a new work bench and ran into a situation where I want to remove a piece of wood from the top. The top is 70in. Long and I’m planing on using the table saw to cut it. Question is, should I try to cut along the side of the glue line, or should I cut the center of the glue line?
View Mark Kornell's profile
Mark Kornell
1169 posts in 2466 days
#1 posted 03-24-2016 04:28 AM
I’m guessing you need to make the top a bit narrower? Depending on what you want your final width to be, I’d be aiming to cut on a glue line. Not necessarily dead center, but so that the glue line is removed by the saw.
Cutting down a glue line doesn’t make a difference to the saw.
-- Mark Kornell, Kornell Wood Design
View jerryminer's profile
909 posts in 1376 days
#2 posted 03-24-2016 08:21 AM
^ +1. Cut all the glue out. Wood glue will stick to wood much better than to cured glue.
4909 posts in 2428 days
#3 posted 03-24-2016 10:44 AM
If you cut the glue out, any rejoining is going to work much better…as mentioned the saw (and blade) doesn’t care.
View Cato's profile
701 posts in 3247 days
#4 posted 03-24-2016 12:00 PM
I had to do the same thing to the ash top on my workbench. Top was too heavy so I used my circular saw to rip it into 3 sections, edge jointed it, then went to the TS for final trimming before gluing it back up. I did not cut on the glue line but rather focused on the size of the panels to fit my planer since I was basically re-milling the top and inserting a replacement board for one that had warped when the workbench had been in a storage unit for 2 years.
