Question for electricians/electronics people
« back to Coffee Lounge forum
Forum topic by InstantSiv posted 03-23-2016 03:56 AM 699 views 0 times favorited 8 replies Add to Favorites Watch
View InstantSiv's profile
InstantSiv
262 posts in 1589 days
03-23-2016 03:56 AM
My tablet wouldn’t turn on so I troubleshooted it and came to the conclusion that it was the power cable that broke. I took a reading with a multimeter and the voltage was fluctuating between 0.06 volts and 2.86 volts. It’s suppose to output 12 volts, time for a new power cable.
The power cable has a box in the middle, which I’m assuming is the transformer. That’s suppose to convert AC to DC right? Here’s the question… the multimeter was showing a fluctuation in voltage… Is that transformer failing to convert the ac to DC and letting ac thru?
8 replies so far
TopamaxSurvivor
18266 posts in 3670 days
#1 posted 03-23-2016 07:12 AM
Hard to tell. Depends on the quality of the meter and the settings.
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1617 days
#2 posted 03-23-2016 10:59 AM
Doubtful it’s “letting AC through”. More likely it’s a broken wire. Power supply wires tend to break at the point where the wire exits the strain relief, either at the case or at the plug end. See if the voltage changes when you flex the wire at those points.
-- Malcolm Laurel - http://MalcolmLaurel.com
InstantSiv
#3 posted 03-23-2016 03:17 PM
- TopamaxSurvivor
Only the best
Doubtful it s “letting AC through”. More likely it s a broken wire. Power supply wires tend to break at the point where the wire exits the strain relief, either at the case or at the plug end. See if the voltage changes when you flex the wire at those points.
- MalcolmLaurel
I didn’t see any changes when manipulating the cord. The voltage was fluctuating very consistently between 0.06 volts and 2.86 and the pace was very consistently too… would cord damage act in this way?
View bonesbr549's profile
bonesbr549
1544 posts in 3061 days
#4 posted 03-23-2016 05:46 PM
power cords fail with regularity. If you are like me, you have a lot of cords around. Look for another transformer that has the same dc voltage out and amps and polarity to test. I’ve had several die and scavaged replacements. The big thing is making sure that polarity is the same easy way to tell is on the ps you will see a + & a – and either an arrow or a line and a semicircle surrounding one side that will indicate polarity. Something else to keep in mind if your battery is totally shot, it will not come on at all. I know I’ve got one, thats down to shutting down if its not constantly plugged in to wall power. It will degrade to the point soon and I will have to breakdown and buy a batt.
From you explanation it does appear the ps may be dying.
I hate buying batts/power supplies for laptops, cost a freak’n fortune.
Good luck.
TopamaxSurvivor
#5 posted 03-23-2016 06:03 PM
Most digital meters see ghost voltages under many conditions. Most likely what you are seeing. An analog meter would probably read “0”.
View ChrisK's profile
ChrisK
1959 posts in 3075 days
#6 posted 03-23-2016 06:49 PM
The input to the tablet should be DC, make sure the meter is on DC
A non RMS AC meter will not show the correct voltage unless the voltage wave is a pure sine wave. So any noise on the DC will so as an AC voltage, but you will not really know what it is.
-- Chris K
View patcollins's profile
patcollins
1685 posts in 2859 days
#7 posted 03-24-2016 12:20 AM
It is most likely supposed to be 5 volts DC, is it a mini-usb or micro-usb connector that attaches to your tablet?
Do you really mean tablet or laptop? I have never seen a tablet take any sort of charger that wasn’t a cell phone charger.
InstantSiv
#8 posted 03-25-2016 02:21 AM
power cords fail with regularity. If you are like me, you have a lot of cords around. Look for another transformer that has the same dc voltage out and amps and polarity to test. I ve had several die and scavaged replacements. The big thing is making sure that polarity is the same easy way to tell is on the ps you will see a + & a – and either an arrow or a line and a semicircle surrounding one side that will indicate polarity. Something else to keep in mind if your battery is totally shot, it will not come on at all. I know I ve got one, thats down to shutting down if its not constantly plugged in to wall power. It will degrade to the point soon and I will have to breakdown and buy a batt.
I hate buying batts/power supplies for laptops, cost a freak n fortune.
Good luck.
- bonesbr549
Unfortunately the power cord is designed in such a way that I cannot use an older cord. They want $70 for an oem cord! $30-$40 for an off brand of good quality… I went with the cheap Chinese ones for $15.
- ChrisK
It was on DC. So the fluctuation could be noise? Interesting…
Do you really mean tablet or laptop? I have never seen a tablet take any sort of charger that wasn t a cell phone charger.
- patcollins
Surface Pro 3. I know it’s not technically a tablet, it’s an actual full computer but it’s in a tablet form so that’s what I call it. The charger outputs 12v.
