Unisaw Worm Gear Disassembly Fury and Torment
Forum topic by bigjim21 posted 03-22-2016 01:56 AM 942 views 0 times favorited 7 replies Add to Favorites Watch
View bigjim21's profile
bigjim21
5 posts in 1039 days
03-22-2016 01:56 AM
Topic tags/keywords: unisaw rebuild worm gear gear worms 34-802
I am rebuilding a 34-802 Unisaw from 1988 and I have the entire saw apart and in pieces, but I can’t get the worm gears off the tilt and blade-lifting shafts to save my life. I’ve pulled the roll pins, the stop collars are sliding freely, but I absolutely cannot figure out what sort of dark magic is involved in getting those worm gears to slide free.
Having had a very long and storied history with banging on things until they break, I have opted not to do that this time.
Does anybody know the magic trick?? I will love you longtime.
7 replies so far
MrUnix
7106 posts in 2435 days
#1 posted 03-22-2016 01:59 AM
Clean the shaft spotless, make sure the roll pins are completely removed, and they will come off. They are a precision fit and the slightest little burr or accumulated rust/gunk will hang them up.
bigjim21
#2 posted 03-22-2016 02:02 AM
ok but how do I make them come off. bang on it? from what direction? with what? how? how hard? the one that tilts the blade is mounted all the way at the end of a shaft so its almost impossible to get anything on it. the other end of that shaft has bullets in it that lock the shaft – so it wont come out from that direction.
do you use a bearing puller on it or something from the far end?
View Holbs's profile
Holbs
2032 posts in 2265 days
#3 posted 03-22-2016 02:07 AM
whack with a rubber mallet first, penetrating oil overnight second. The worm gear is only held by 1? 2? roll pins, nothing else. If it is still stuck, something else is amiss.
Holbs
#4 posted 03-22-2016 02:12 AM
I had to do the same as you Jim, rather recently. Rebuild of my Unisaw. Looking at the parts diagram this Monday, the tilting worm gear has 2 roll pins while the raise/lower worm gear has plugs. I can’t remember :)
Holbs
#5 posted 03-22-2016 02:18 AM
Unsure if this helps, but here are a couple pics of my rebuild with views of the worm gears:
bigjim21
#6 posted 03-22-2016 02:36 AM
looks really nice. did you polish the rod or is that paint? new gears?
mine only have one roll pin apiece that i can find. it came out fairly easily.
MrUnix
#7 posted 03-22-2016 02:41 AM
Only one roll pin per gear. Be thankful you don’t have tapered pins instead :)
PS: If you haven’t already read them, there are a couple of good disassembly/assembly articles over at the VintageMachinery site (here and here).
