table saw outlet location
Forum topic by DalyArcher posted 03-21-2016 07:12 PM 1289 views 0 times favorited 16 replies Add to Favorites Watch
View DalyArcher's profile (online now)
DalyArcher
114 posts in 1083 days
03-21-2016 07:12 PM
Topic tags/keywords: tablesaw question
I know this has been thrown around before, but I am going to ask again. I am planning out my new shop , building right from the ground up. 20’ x 24’, slab on grade with 10 foot ceilings. Polished concrete will be the finished floor material (with a bit of a “gripy” application) What is your preferred method for getting power to your tablesaw? Extension cord to a wall plug, ceiling drop or floor plug.
I am contemplating the floor plug, but a few things have me pushing away from it. 1 – it really locks the location of the saw and I have to make the decision before pouring, and thus before I have had a feel for the space and solidified layout. 2 – I will never have vehicles in there, but I may wish to hang a deer or moose in there, push the tablesaw aside and butcher in the shop as opposed to my wifes kitchen. The floor pug makes the idea of washing down the floor un-appealing. Plus, my luck, I know at least once I will kick over a bucket of finish or spirits…
The ceiling drop has its appeal as it can be done somewhat after lockup when I have a better feel for location of major tools.
Wall plug seems the easiest and may keep me in the habit of unplugging at blade changes.
So, who does what?
16 replies so far
View ScottM's profile
ScottM
625 posts in 2110 days
#1 posted 03-21-2016 07:16 PM
I’d say keep the floor clean. If you plug in to the floor you’re going to kick it, step on it, etc. Just run an extension cord to the wall, but keep in mind the distance and gauge depending on your voltage.
View Ghidrah's profile
Ghidrah
667 posts in 1185 days
#2 posted 03-21-2016 07:20 PM
Agree with ScottM, I have 5 outlets at the perimeter and 2 cables, 115 and 230 that reach across the shop for either type of tool.
-- I meant to do that!
View GregD's profile
GregD
788 posts in 3099 days
#3 posted 03-21-2016 07:27 PM
I like ceiling drops in my garage shop. The outlets are nailed to joists and I have short extension cords that hang down just low enough for me to reach them. My garage is unfinished and I installed the outlets myself so there is a possibility that what I have is not up to code. But it has been easy to live with and to modify as needed.
-- Greg D.
View hotbyte's profile
hotbyte
991 posts in 2939 days
#4 posted 03-21-2016 07:53 PM
Mine is on heavy duty drop cord to wall outlet on right side of saw. I keep saw closer to wall on the right.
The ceiling drop is interesting…does it ever get i the way of passing material across saw? Where, approximately, does it drop down?
View chiseler's profile
chiseler
124 posts in 852 days
#5 posted 03-21-2016 09:38 PM
My TS is in the center of the shop,and I ran plastic conduit in the floor and it come out just behind the TS under the out feed table and I mounted a 6”x6” plastic box that sits about 4”off the floor,(impossible to trip over).In that box I put a circuit for the TS,a circuit for the joiner which is directly to the left of the saw(I frequently run saw and joiner at the same time),a 220 A extension cord hard wired in the box for my Planer which is on wheels,and last but not least a 110A outlet.It is all completely out of the way,no cords to trip over,and nothing hanging from the ceiling to get in the way for those precarious cuts.
And the box is vertical,so can’t fill up with dust
And yes,I built my shop from the ground up,and
I put it on piers so I have a wood floor.
You could do the same thing by laying pipe in the concrete
-- Scott.Triangle,NY Becareful and don't forget...They cut meat too! Ask me how I know
View klassenl's profile
klassenl
185 posts in 2622 days
#6 posted 03-22-2016 12:12 AM
In the floor.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
View David Taylor's profile
David Taylor
326 posts in 1050 days
#7 posted 03-22-2016 03:05 AM
Like chiseler I have a wood floor shop on sonnet tubes I put a box in the center of the floor, right under the TS for it. It’s actually a box for setting in poured concrete, has a pretty good seal system, so dust doesn’t seem to bother it. Hopefully, I don’t spill anything down there, but I think I can be relatively careful of that.
-- Learn Relentlessly
chiseler
#8 posted 03-22-2016 03:33 AM
Like chiseler I have a wood floor shop on sonnet tubes I put a box in the center of the floor, right under the TS for it. It s actually a box for setting in poured concrete, has a pretty good seal system, so dust doesn t seem to bother it. Hopefully, I don t spill anything down there, but I think I can be relatively careful of that.
- David Taylor
My outlets are actually vertical.The box is about 4” above the floor then braced up with some 2x material
Scott
David Taylor
#9 posted 03-24-2016 11:38 PM
Scott, oh, that’s even better than my setup I wish I had thought of that :)
View Roger's profile
Roger
20923 posts in 2767 days
#10 posted 03-25-2016 01:06 AM
If I were building a shop from the ground up, I would definitely put the plug in the middle of the floor, or in the spot where you know the table saw will live. A friend of mine done that many years ago, and I thought that was a gr8 idea. The only thing is, of course, you have to have a very good idea of a layout/floor plan of how you’re going to place your equipment. Also, I’d be sure to add a few 220 plugs here and there where you think you might need it. That seems to be an ever-changing thing, kinda/sorta. Good luck. New shop construction is always a fun fun thing. Work/Play safe.
View eflanders's profile
eflanders
294 posts in 1814 days
#11 posted 03-25-2016 03:41 PM
New shop, I would defiantly go with wall receptacles. Why? Floor receptacles collect stuff, it happens and any future potential buyer may not want floor outlets in their shop. They are easier to modify should you decide to voltage or receptacle style. Lastly, I’ve had my shop in the basement for years, and I’ve changed machinery locations multiple times. Just my .02 opinion…
View Kazooman's profile
Kazooman
997 posts in 1916 days
#12 posted 03-25-2016 04:27 PM
If you decide on floor outlets, you could rough in several locations with conduit so that relocating the saw or adding other machines ibn the future would just require pulling the cable and installing the outlets.
View helluvawreck's profile
helluvawreck
30765 posts in 2830 days
#13 posted 03-25-2016 05:19 PM
Think about all of the machinery you will have in the middle away from the walls and then spend some time laying out your shop. Once you figure out where things are going then run the middle machines from plugs coming out of the floor. Make sure it’s done according to code. I love the way it works in my shop and have been using it for at least a couple of years. I only have one machine away from the wall that gets it’s power from the ceiling and it’s my joiner. I move it around a little so it’s better that the cord has a little slack and comes from the ceiling.
helluvawreck aka Charles
View Andre's profile
Andre
1780 posts in 1769 days
#14 posted 03-25-2016 05:29 PM
I went with ceiling drop along with D.C. line, not much choice as went with in floor heating. My shop is 24’ by 24’ and like yours is a dedicated shop.
View biggeorge50's profile
biggeorge50
14 posts in 2155 days
#15 posted 03-25-2016 06:23 PM
My shop is in my basement. I ran one dedicated circuit for the dust collector to a wall socket. I then put in 3 circuits along the ceiling joists with boxes about every 3 feet. I like the cords being out from underfoot.
