Question about joining plywood
« back to Joinery forum
Forum topic by jmeter posted 03-21-2016 02:57 AM 982 views 0 times favorited 17 replies Add to Favorites Watch
View jmeter's profile
jmeter
11 posts in 1084 days
03-21-2016 02:57 AM
Hi Lumber Jocks,
I’m fairly new to woodworking and have a project to make 16 plywood pedestals for an exhibition. I’m going to be making it out of birch ply and there can’t be any visible fasteners. They are fine with a butt joint and want it to be as cheap as possible.
Would a glued butt joint be feasible/strong enough? Should I use brackets? Not sure what would be an easy way to make these and any input would be greatly appreciated.
17 replies so far
View joey502's profile
joey502
535 posts in 1518 days
#1 posted 03-21-2016 03:52 AM
Do you have a sketch of the design to give a rough idea of the shape and size? What will be sitting on the display pedestal?
woodbutcherbynight
4569 posts in 2409 days
#2 posted 03-21-2016 03:56 AM
No visible fasteners and as cheap as possible? Pocket holes maybe?
View chiseler's profile
chiseler
124 posts in 888 days
#3 posted 03-21-2016 04:02 AM
The butt joint is the weakest joint there is and depending on the size of the pieces(bigger is not good) without any type of mechanical fasteners,(screws,nails,bolts ,brackets) the glue joints will fail under the slightest bit of stress
-- Scott.Triangle,NY Becareful and don't forget...They cut meat too! Ask me how I know
jmeter
#4 posted 03-21-2016 04:11 AM
Hi guys, thanks for the responses. The pedestals will be 10” x 10” x 40”. I’m thinking of using 3/4” birch ply. Not exactly sure what amount of weight will be in them. I can make a sketch tomorrow morning to demonstrate.
View hairy's profile (online now)
hairy
2704 posts in 3532 days
#5 posted 03-21-2016 01:38 PM
Some food for thought…
http://lumberjocks.com/projects/189306
You will need either a router table and bit or table saw with dado blade.
-- My reality check bounced...
View pintodeluxe's profile
pintodeluxe
5661 posts in 2813 days
#6 posted 03-21-2016 03:28 PM
Rabbets or biscuits and glue will work fine.
Pocket hole screws would work fine.
View AlaskaGuy's profile
AlaskaGuy
4140 posts in 2309 days
#7 posted 03-21-2016 05:01 PM
I’m waiting for the sketch.
In the mean time cheap and no visible fasteners =butt joints with tapered plugs cut off and sanded smooth.
For a more refined product I’d use biscuits or better yet domino’s.
At this point there been no mention of plywood edge grain showing so the above could change depending.
The better information given the better the chance of getting better answers.
View cdaniels's profile
cdaniels
1320 posts in 1501 days
#8 posted 03-21-2016 05:33 PM
I would edge band it, a roll of that stuff is cheap and looks good and use pocket screws, strong and hidden, cheap and easy to do.
-- Jesus was a carpenter... I'm just saying
View MadMark's profile
MadMark
979 posts in 1453 days
#9 posted 03-21-2016 05:45 PM
Biscuit joiner is the right tool.
M
View RogerM's profile
RogerM
792 posts in 2399 days
#10 posted 03-21-2016 05:48 PM
Pocket holes or biscuits would be the best and cheapest joints.
-- Roger M, Aiken, SC
AlaskaGuy
#11 posted 03-21-2016 05:57 PM
I also wonder how he plans to finish these. He didn’t say anything on finishing either.
View jerryminer's profile
jerryminer
923 posts in 1441 days
#12 posted 03-22-2016 01:17 AM
No visible fasteners, but visible plywood edge is OK? Must be for an artist
View bruc101's profile
bruc101
1200 posts in 3542 days
#13 posted 03-22-2016 01:26 AM
Mortise and tenon glued and clamped.
-- Bruce Free Plans http://plans.sawmillvalley.org
woodbutcherbynight
#14 posted 03-22-2016 01:47 AM
- jerryminer
ROFLMAO
bruc101
#15 posted 03-22-2016 03:09 AM
Michael Gilmartin…furniture maker in Atlanta He builds furniture out of plywood. Highland Hardware did a video with him in hiis workshop. I think he uses a special order Douglas Fir plywood. In his video he said he was inspired to deign and build this chair from a plumber.
