Forum topic by BoomWood | posted 03-20-2016 03:56 PM | 739 views | 0 times favorited | 9 replies | ![]() |
Im currently making a jewelry box tray and was trying to route a rabbet for the bottom of the tray. It screwed up my pieces and I’m not sure what I’m doing wrong. I started with the router speed at 5 and lowered it down to 1. |
9 replies so far
#1 posted 03-20-2016 04:02 PM |
Are you feeding from right to left? Also try and take less wood out and work up to your final depth. -- Knowledge and experience equals Wisdom, Michael Frankowski |
#2 posted 03-20-2016 04:03 PM |
Yup right to left, also only taking out an 1/8”. I figured since it’s so little I could do it in one pass? |
#3 posted 03-20-2016 04:05 PM |
I’d route first and miter last |
#4 posted 03-20-2016 04:07 PM |
You’re going to get nine thousand different answers and suggestions on this…...Here is mine….. 1. Move the fence forward and take smaller bites. Move the fence back in small increments until desired depth is achieved. 2. Use a backer board when running any kind of profile. 3. Speed on that bit should run around 12,000 to 15,000 RPM That should fix the problem. |
#5 posted 03-20-2016 04:10 PM |
Yes, I defintely will route first and miter last next time. |
#6 posted 03-20-2016 04:27 PM |
RTFM! -- Madmark - Madmark2150@yahoo.com Wiretreefarm.com |
#7 posted 03-20-2016 05:33 PM |
I’d be doing that on a table saw with a dado blade…......easy pleasy in one pass no tear out. -- Alaskan's for Global warming! |
#8 posted 03-21-2016 01:19 AM |
I’m trying to understand how you got the cut we see while feeding right-to-left. Thinking maybe you ran the pieces on edge, freehand, without having the fence in line with the bearing? And the bit grabbed and climbed into the mitered section? (Hope your fingers were out of the way. That would be a dangerous approach) Better to put the fence in line with the bearing (use a straight edge to keep everything in line) and keep the material against the fence at all times. -- Jerry, making sawdust professionally since 1976 |
#9 posted 03-21-2016 05:01 AM |
When ever jointing,planing,or machining wood ,you have to pay attention to what’s called grain run out(grain direction).If you don’t,and you machine against the run out,you take the chance of tearing out the grain.Where it can’t be helped you were better off starting with a shallow saw cut first. I hope this helps -- Scott.Triangle,NY Becareful and don't forget...They cut meat too! Ask me how I know |
Forum | Topics |
Woodworking Skill Share
12031 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4905 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5411 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
