Help, i made a jointer/taper jig for my table saw, but can't joint can only get tapers
Forum topic by Johnalan1 posted 03-20-2016 02:40 PM 1165 views 0 times favorited 13 replies Add to Favorites Watch
View Johnalan1's profile
Johnalan1
39 posts in 770 days
03-20-2016 02:40 PM
Topic tags/keywords: jig question tip help table saw tapering jig tapering jointing
Hello, i’ve made a tapering jig (i can add pics if you want) i basically copied this design ”:http://www.simplyeasydiy.com/2014/02/diy-table-saw-jointing-and-tapering-jig.html”
I ordered adhesive ruler tape, i hope that will help,
how do i keep from cutting a taper? i’m trying to joint but i keep cutting a slight taper, one end will be 5 1/2 and one will be 5 3/4.
any suggestions would be greatly appreciated
-- John Darlington Sc https://www.etsy.com/shop/JohnsScrollsaw
13 replies so far
Johnalan1
#1 posted 03-20-2016 03:08 PM
i forgot to add, the base i was useing was perfectly (enough within a 64th) straight i used mdf shevling stock
View Mark's profile
Mark
874 posts in 1850 days
#2 posted 03-20-2016 03:42 PM
I made one of these things several yrs ago and have always had great success. 1/4” in 8’(?) that’s quite a bit. Are you sure your blade is parallel to the fence? There’s not to much else that will effect the cut.
-- Mark
Johnalan1
#3 posted 03-20-2016 04:01 PM
now thinking of it the rip fence is was prob out of square i just have a cheap table saw and the rip fence is one that can lock at an angle
View jerryminer's profile
jerryminer
850 posts in 1317 days
#4 posted 03-20-2016 04:52 PM
I (respectfully) disagree with that diagnosis
An out-of-line rip fence will produce a rough cut and/or burning, but if the workpiece is kept tight to the fence as it passes the blade, the two edges will be parallel, not tapered.
I think your work is either not placed in the jig parallel to the fence, or it is not staying in that position. Could it be shifting during processing? Or is the jig drifting away from the fence?
View Rick_M's profile
Rick_M
10843 posts in 2256 days
#5 posted 03-20-2016 05:04 PM
Jointing does not produce parallel sides, it makes something flat and/or perpendicular to an adjoining side. Joint first, then use just your TS to rip and make the edges parallel.
-- http://thewoodknack.blogspot.com/
View Richard H's profile
Richard H
489 posts in 1556 days
#6 posted 03-20-2016 05:13 PM
What are you referencing off of when you set the board to be jointed in the jig? The video you posted has the jig running in the miter track so assuming you are doing the same that is what establishes the reference edge. If you left the jig oversized and cut off the excess the first time you ran it though the blade than the edge against the blade should be parallel to that miter slot however the other right edge of the jig is probably not parallel and not a reference edge. When setting up your piece to be jointed measure off the left edge assuming you cut it parallel not the right edge. Is the spacing between the blade and the left edge of the jig consistent or does a gap open up as you push the jig by the blade?
Also as Rick M. said you only use this jig for one edge than flip the board around and use the freshly sawn edge against your rip fence to make two edges parallel to each other.
Hope this helps,
jerryminer
#7 posted 03-20-2016 05:14 PM
- Rick M.
Yes, but we’re not talking about jointing on a jointer. We’re talking about getting “jointed” edges on a tablesaw.
View AlaskaGuy's profile
AlaskaGuy
3797 posts in 2185 days
#8 posted 03-20-2016 05:28 PM
Are you using that jig to “joint” both sides of the same board?
Rick_M
#9 posted 03-20-2016 05:55 PM
Yes, but …
- jerryminer
There is no “but”. It doesn’t matter if you are using a jointer, a saw, or a hand plane; jointing does not produce parallel edges. The problem isn’t the jig, it’s a misunderstanding of the terminology and proper way to dress rough lumber.
Order of operations from rough stock, can be done with power or hand tools:
1) joint one face
2) joint one edge
3) plane faces parallel
4) cut edges parallel
jerryminer
#10 posted 03-20-2016 06:03 PM
Rick M—
Good point.
Joint first, then rip parallel
Johnalan1
#11 posted 03-20-2016 11:14 PM
@alaskaguy, no, @richardh, no i do it along my fence
View rubber_ducky's profile
rubber_ducky
36 posts in 754 days
#12 posted 03-20-2016 11:45 PM
I agree with what many of the others have said already. If you’re only using your jig to joint one edge of the board and using your TS fence to rip the opposite edge to width and you’re ending up out of parallel, then the problem is unlikely in the jig but rather in the TS fence.
Rick_M
#13 posted 03-21-2016 01:23 AM
<blockquote>
- Johnalan1
</blockquote>
Explain your procedure and equipment used, be specific.
