How to make this top
Forum topic by Gixxerjoe04 posted 03-20-2016 01:23 PM 813 views 0 times favorited 6 replies Add to Favorites Watch
View Gixxerjoe04's profile
Gixxerjoe04
850 posts in 1778 days
03-20-2016 01:23 PM
I’ve got a friend who needs a new top made for a cedar blanket chest after her dog made one side a chew toy. The original one has trim around it that extends down to go around the outside of the chest. Originally I didn’t notice the lip and was just going to make the edge profile match the best I could and not add the trim because I didn’t want to have worry about wood movement. Now I gotta figure out what I should do to make the lip around the outside, the original one was just nailed on. Any suggestions? And yes she did stain the outside of a cedar chest for some reason haha
View gwilki's profile
gwilki
226 posts in 1675 days
#1 posted 03-20-2016 02:40 PM
Route the profile you want into the side grain of your wood, then dado out the back of the “moulding” you just made to give you the overhang you want. It’s like making a picture frame – sort of.
To attach it to the top itself, I would use glue and pin nails. But, you can simply glue and tape clamp it, too.
-- Grant Wilkinson, Ottawa ON
View jerryminer's profile
jerryminer
944 posts in 1643 days
#2 posted 03-20-2016 05:07 PM
If you duplicate the original construction, you will have issues with wood movement—-as the original had (we see the crack at the nail in the pic).
Possible approaches:
Use plywood for the top (which could be veneered with cedar or whatever)
Breadboard ends
Make the lipping from solid stock and use end-grain at the ends
Make a frame-and panel top with a floating panel
Accept (and have the client accept) the risk of movement and use the original nail-on system
View Aj2's profile (online now)
Aj2
1878 posts in 1999 days
#3 posted 03-20-2016 08:34 PM
What a perfect pic of long grain cross grain wood movement. The nail with a crack.
-- Aj
19440 posts in 2058 days
#4 posted 03-20-2016 08:48 PM
I think Grant said what I’m thinking. Make a top that’s thick enough to create the profile. Then route out a channel in the underside that allows the top to fit down over the box.
View CaptainSkully's profile
CaptainSkully
1602 posts in 3760 days
#5 posted 03-24-2016 01:42 PM
I think the best way to do it, if you’re going to do it right, is try to find a router bit for that profile. If not, custom shaper blades can be made for your table saw pretty reasonably. Make the profiled edges out of solid wood and wrap a piece of veneered plywood of the same species. Today’s glues are strong enough, especially if you make a rabbet in the solid wood to accept the plywood edge and give it a shoulder to positively locate on.
-- You can't control the wind, but you can trim your sails
View JAAune's profile
JAAune
1853 posts in 2518 days
#6 posted 03-24-2016 02:00 PM
The pieces on the end can be installed with sliding dovetails. Then glue the first 8-12” to the panel but leave the rest floating.
