Machine advice
Forum topic by jdegg posted 03-20-2016 03:59 AM 719 views 0 times favorited 3 replies Add to Favorites Watch
View jdegg's profile
jdegg
1 post in 762 days
03-20-2016 03:59 AM
I’m sorry if I’m posting this in the wrong section, but I’m very new to this.
My needs are: cut 1/2” plywood with a machine that is fully automatic. For example, I could set a 30”x30” piece and have it auto cut into the shape or a star or circle. And I need to be do be able to do this through software.  I understand this might be quite expensive and I’m fine with that.  Just want a good piece of equipment.
What machines should I be looking at? Just not sure where to get started in this process and would appreciate any direction or help.
Thanks!
3 replies so far
View jerryminer's profile
jerryminer
916 posts in 1405 days
#1 posted 03-20-2016 05:03 AM
CNC router
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1587 days
#2 posted 03-20-2016 12:46 PM
^^^ This. You can even build one yourself if you’re so inclined; lots of information out there. Or if you want even more precision and sharp inside corners, a CNC laser cutter.
-- Malcolm Laurel - http://MalcolmLaurel.com
View JAAune's profile
JAAune
1786 posts in 2280 days
#3 posted 03-20-2016 06:53 PM
A laser that can cut 30”x30”x1/2” plywood sheets would be very expensive. It will also leave darkened edges. The CNC router is probably the better tool in most cases.
