Jet Deluxe Xacta Saw 3hp
Forum topic by JustLikeJames posted 03-19-2016 11:14 PM 2141 views 0 times favorited 59 replies Add to Favorites Watch
View JustLikeJames's profile
JustLikeJames
173 posts in 1802 days
03-19-2016 11:14 PM
Topic tags/keywords: jet table saw xacta 3hp
I just got done assembling and adjusting my new Jet table saw. I’ve turned it on and off a couple of times but haven’t used it yet. When I hit the stop button, as the blade is slowing down, the belt vibrates (flutters) and makes a horrible noise, almost like the motor is braking to stop the blade. The noise and vibration is only momentary, then the blade slows down quietly from there.
Anybody else have this issue on a Jet table saw? Is it just the motor braking, should I adjust the belt tension, will the issue go away after a little break in time?
Thanks.
59 replies so far
JustLikeJames
#1 posted 03-19-2016 11:17 PM
I would just call tech support about it, but of course I discovered it while they are closed.
View conifur's profile
conifur
955 posts in 1392 days
#2 posted 03-19-2016 11:26 PM
What is the belt tension like?
View rwe2156's profile
rwe2156
3235 posts in 1721 days
#3 posted 03-19-2016 11:27 PM
Yes, mine (Jet Xacta Cut Gold Series) has done it from day 1. After After 10 or 12 years I’m so used to it now I don’t even hear it. I think it does have something to do with braking.
I would call but I’ll be they tell you its normal.
JustLikeJames
#4 posted 03-19-2016 11:31 PM
- conifur
I can deflect the belt about 1/4” (at least) with light pressure from one finger. It runs smooth when up to speed, it’s just rough as it slows down. Sounds like it wouldn’t hurt to try adjusting the belt tension. I hope it doesn’t still do it years from now.
MrUnix
7107 posts in 2439 days
#5 posted 03-19-2016 11:40 PM
More likely just the centrifugal switch closing during spin down.
JustLikeJames
#6 posted 03-19-2016 11:49 PM
- MrUnix
“Centrifugal switch”, what is that and why would it cause the vibration?
MrUnix
#7 posted 03-20-2016 02:14 AM
- JustLikeJames
Spring loaded switch inside the motor that controls the start circuit. When the motor spins down, it kicks out (or pulls in depending on design) to close the start circuit contacts. It’s what causes the typical ‘clunk’ that can be heard as the motor spins down and frequently confused as being some sort of brake.
View knotscott's profile
knotscott
8180 posts in 3616 days
#8 posted 03-20-2016 11:36 AM
It could be from belt tension, minor deviations in the belts, pulleys, runout in the arbor, flange, or blade, but there’s an electrical phenomenon known as regeneration that’s an electrical interaction with the motor capacitors that can occur at shutdown that causes some minor shuddering for a brief moment. IIRC, the motor basically becomes a generator for a brief period when the motor shuts down…it could indeed correspond to when the centrifugal switch disengages. There are some fixes that involve putting a resistor across the caps, but if the belts are good, and all else is functioning as it should, I wouldn’t worry much about it.
JustLikeJames
#9 posted 03-20-2016 03:04 PM
Wow, you guys are great! I swear I had replies faster than tech support would even answer the phone.
I’m only worried about it because it’s a sound like it’s not supposed to do that (you know, sometimes you can just tell). Clearly, the belt and pulley are spinning at different speeds when the belt vibrates, then it takes a second for the pulley to grab on again. I just don’t know what’s causing them to get out of sync with each other.
I am going to check the pulley/arbor alignment then I’ll see if tightening the belt makes any difference. If all else fails, I’ll call tech support Monday after work.
Thanks everybody.
View Cato's profile
Cato
701 posts in 3553 days
#10 posted 03-20-2016 07:36 PM
I have the 3hp Xacta deluxe and just fired it up and then off. Mine just slowly spins down but doesn’t make any strange noise. It does sound like it is slowly braking but no shudders or vibrations.
JustLikeJames
#11 posted 03-20-2016 08:42 PM
I have the 3hp Xacta deluxe and just fired it up and then off. Mine just slowly spins down but doesn t make any strange noise. It does sound like it is slowly braking but no shudders or vibrations.
- Cato
Thanks, good to hear it isn’t supposed to shudder like mine does. I tightened up the belt and it only made a slight improvement (if at all). Looks like I’ll have to give tech support a call tomorrow. Hopefully I can work it out over the phone with them.
JustLikeJames
#12 posted 03-21-2016 12:40 AM
Just to rule things out, I ran the saw without the blade in and it didn’t make the noise. The motor makes one click during slowdown (which seems normal), but the belt doesn’t vibrate violently. I’ve tried it with multiple blades just to rule that out too, but they all make the belt vibrate during slowdown. Weird.
View Julian's profile
Julian
1434 posts in 2931 days
#13 posted 03-21-2016 01:33 AM
I have the same saw; about 5 years old. Mines does not making any noise when I turn it off. It smoothly coasts to a stop.
-- Julian
View TheFridge's profile
TheFridge
10818 posts in 1726 days
#14 posted 03-21-2016 02:00 AM
Try tightening the belt up a hair and check?
JustLikeJames
#15 posted 03-21-2016 03:27 AM
- TheFridge
By the way, did you catch my comment about how the vibration/noise doesn’t happen without a blade mounted. Without a blade mounted, it is very smooth slow down.
I have tightened it quite a bit tighter than from the factory. I pulled down on the motor a little. The improvement was very slight, if any. Whatever is triggering the vibration still remains. I didn’t want to risk getting it any tighter (in case there’s such a thing as too tight) and doing more harm than good.
showing 1 through 15 of 59 replies
