What type of glue
« back to Joinery forum
Forum topic by KWiK posted 03-19-2016 10:54 PM 669 views 0 times favorited 5 replies Add to Favorites Watch
View KWiK's profile
KWiK
29 posts in 871 days
03-19-2016 10:54 PM
I got the fit a little to tight when I inserted the strips in this, and got a this crack between the two. Which would be better glue to use, tightbond, or CA Glue? I could just cut through the handles, and continue the stripes, but I like the look this way.
5 replies so far
View rwe2156's profile
rwe2156
2923 posts in 1476 days
#1 posted 03-19-2016 11:29 PM
Epoxy. Looks like you need gap filling glue.
You can add some tine or sawdust to the glue.
View conifur's profile
conifur
955 posts in 1147 days
#2 posted 03-19-2016 11:29 PM
I would like a better discripsion of what you are trying to achieve.
View Ger21's profile
Ger21
1074 posts in 3126 days
#3 posted 03-19-2016 11:36 PM
+1
If you try to close the gap, there’s a good chance it will split somewhere else.
You could also make a saw cut and add a new 1/8” piece in there.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View KWiK's profile
KWiK
#4 posted 03-19-2016 11:55 PM
The gap is about the width of a exacto knife, and you can only get that in a little ways. The reason I was considering CA was was thinking the slower setting stuff might be thinner and have a better chance to get down in farther. I suppose Epoxy is a lot slower setting, so I could work it down in better, before it hardens. It doesn’t take much to close the gap. I think a rubber band would do it.
View gfadvm's profile
gfadvm
14940 posts in 2685 days
#5 posted 03-20-2016 12:05 AM
Titebond will work fine but use your shopvac to pull glue through the entire crack before clamping.
