| Forum topic by williams | posted 1202 days ago | 941 views | 1 time favorited | 3 replies | ![]() |
1202 days ago |
Topic tags/keywords: plywood Where to get this kind of plywood and what is it called? Nothing close to this at HD. Has like 10+ layers. Looks good for jig making. tia -- William, Brighton, MI |
3 replies so far
#1 posted 1202 days ago |
Looks like Baltic Birch. HD can special order it if you go down to the Pro Desk. Rather expensive though. And you’re right, it is great for jigs. If you’re willing to pay even more, look into phonellic (sp?) coated plywood. One brand is “Finform”. Absolutely wonderful for jigs. A sheet of 3/4” Finform will probably run over $100. If you have an RSC Rental place in your area, you can try there. They carry it for rental by contractors that use it to shore up trenches and excavations. If you pick through their stock, you can often find a good sheet or two. I’ve bought them used for around $75. The phonellic resin coating on both faces makes it a very smooth surface that does not require any finish and it is fairly resistant to abrasion. The core of the Finform is Baltic Birch. -- Dave; Lansing, Kansas |
#2 posted 1202 days ago |
Thanks firehouse. Looks like woodcraft carries both of those. Will check it out. cheers. -- William, Brighton, MI |
#3 posted 1200 days ago |
i get it at menards right off the shelf ;) -- if you dont have it, build it, especially when its a stupid idea |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15980 |
Hand Tools
2097 |
Jigs & Fixtures
501 |
Wood & Lumber
2907 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
