SALE 10" Inca Cabinetmakers TableSaw
Forum topic by quinnjos posted 03-18-2016 04:10 PM 2975 views 0 times favorited 4 replies Add to Favorites Watch
View quinnjos's profile
2 posts in 738 days
03-18-2016 04:10 PM
Topic tags/keywords: inca tablesaw inca 10 tablesaw tablesaw
INCA 10” Cabinetmakers table saw 341.018 Model 259. 20mm (.784 in.) arbor with Inca hardwood stand , motor (1.5 HP, 110 v/220v Continuous Capacity).
Motor wired for 110v. Accessories:
Table Extension Guide Rails: 39.5 in. length and extra extension Table
Mortising Apparatus Table with two Hold down Clamps
Device for Cutting Tenons
Hold down with wheel for ripping
Drum Sander, 1.75 dia.
Abrasive Disk, 6 in. dia.
Wooden Guide for Lock Joint Work
Mortise Drill Bits: 4 ea. : 6mm, 8mm,10mm, 12mm
Milling Drill Bits: 2 ea.: 9/32”, 3/8”
Wobble washers,13/16 arbor (4 ea.)
Saw Blades: 20mm (.784 in.) arbor (most blades are dull) Dado Cutter: 6mm (.236 inch) width 10” chrome nickel 3 ea. (100, 75, 36 teeth) 7” “ “ 1 ea. (200 teeth) 7.25“ -24 teeth Carbide teeth 7-7/8” Carbide teeth 10” 4 ea. 40 teeth Carbide teeth 10” one ea. 24 teeth (new, 5/8” arbor) Carbide teeth 10” sanding dish, .784 arbor
Table Inserts (2 ea.: 1”, 9/64” throat)
Only $500.00. Buyer makes arrangements for pickup and shipping. Sale of home workshop due to age (86). This extraordinary saw has served me well over the years, and has its war wounds. Needs to be disassembled, lineage cleaned, and reassembled (take-down diagram of individual parts included in manual): adjustments are difficult to turn; suspect packed sawdust (or I am weaker with age). Location; Independence, Oregon
View shastaman's profile
30 posts in 785 days
#1 posted 03-19-2016 03:31 AM
86 year old makes his first post here to sell ?
View AlaskaGuy's profile
3988 posts in 2245 days
#2 posted 03-19-2016 06:09 AM
- shastaman
What’s you point??
View Andre's profile
1723 posts in 1742 days
#3 posted 03-19-2016 06:10 AM
If I was a bit closer would take it in a minute!
117032 posts in 3513 days
#4 posted 03-19-2016 11:55 AM
Good luck with your sale sir.Your saw is priced very well.
-- wood crafting & classes
