Drill press pulley nut coming loose
Forum topic by kmetzger posted 03-18-2016 01:49 AM 729 views 0 times favorited 1 reply Add to Favorites Watch
View kmetzger's profile
kmetzger
157 posts in 1783 days
03-18-2016 01:49 AM
I’m having exactly the same problem described by a member a year ago: http://lumberjocks.com/topics/64455
My spindle pulley set nut keeps coming off and it also started happening after a 2” Forstner bit stopped spinning. I made sure my belt were tight and that the set screw in the rear pulley was securely installed. I have a Mexican drill press similar to a Jet but my manual is no help.
Does the set nut have to be tightened down with a wrench?
-- Kim, Ajijic, Mexico, http://tinyurl.com/7w5fm25
1 reply so far
View conifur's profile
conifur
955 posts in 1117 days
#1 posted 03-18-2016 02:00 AM
So the torque of the bit not turning transferred through the shaft to the pulley to the nut. Get a Nylon lock nut or some Blue Loc Tight for it.
