McNaughton coring system questions
« back to Woodturning forum
Forum topic by cdaniels posted 03-17-2016 05:22 PM 818 views 0 times favorited 8 replies Add to Favorites Watch
View cdaniels's profile
cdaniels
1320 posts in 1496 days
03-17-2016 05:22 PM
I just ordered the standard sized McNaughton system for coring out blanks. I also ordered the mike mahoney DVD on recommendation. I’m trying to get as much info as I can before I get started so my questions is when choosing what size blanks to core is there a thickness limit on what you can core? I mean a lot of the logs I get are around 12” diameter which means I get around a 3-5” deep blank so is that enough to get a few cores out of or is that too shallow? I can get much larger pieces but those are the usual sizes that are the most abundant. any advice would be great on the system!
Chris
-- Jesus was a carpenter... I'm just saying
8 replies so far
View Wildwood's profile
Wildwood
2305 posts in 2129 days
#1 posted 03-17-2016 08:14 PM
https://www.youtube.com/watch?v=xk-Z-scS84w
If have any questions can contact Reed by e-mail with address at his web site.
http://www.robohippy.net/store/
-- Bill
View soob's profile
soob
263 posts in 1203 days
#2 posted 03-21-2016 02:28 PM
Thickness of the blank tends to be the limiter. On green wood, you lose 1/2” or so for truing up and the tenon, then for the big bowl you need to leave at least 1” for every 12” of diameter, plus you lose 1/2” for the coring kerf.
So if you start out with a 3” blank there’s basically nothing left for a core.
cdaniels
#3 posted 03-21-2016 03:21 PM
ok thanks that’s about what I was guessing
View soob's profile
soob
#4 posted 03-21-2016 03:29 PM
That being said…
You might be able to cheat a little on the depth (as that’s the maximum depth, after all). If your tenon is going to be a foot on the big bowl, you might be able to get a 1.5”+ thick platter out of that 3” blank.
cdaniels
#5 posted 03-24-2016 05:58 PM
I currently am using a nova G3 chuck with the 50mm jaws that come with it. I’m waiting on a Supernova 2 chuck to come in and I have 100mm Jaws to go on either one. my question is that if I put the 100mm jaws on the G3 will it provide a strong enough hold to core out some 12” x 6” bowls?
Wildwood
#6 posted 03-24-2016 06:27 PM
If get a free Packard catalog tells you the 100 & 130mm jaws only fit SN2 chuck, not sure what Teknatool catalog says!
-- Bill
cdaniels
#7 posted 03-25-2016 12:33 AM
Jaw Travel Range Table
Imperial (Inch)
Jaw Set & Chuck Suitability Expanding Action Specifications Contracting Action Specifications
Jaw Set Suitable Chuck Square Stock Spigot Mode
Min Max Min Max Min Max
100mm JAW Precision Midi* Not Recommended Not Recommended Not Recommended
Nova G3 3.819 4.646 2.205 3.031 3.071 3.898
SuperNova2 3.819 4.646 2.205 3.031 3.071 3.898
Titan 3.819 5.039 2.205 3.425 3.071 4.291
Wildwood
#8 posted 03-25-2016 12:06 PM
After posting went looking for an answer, didn’t know if Packard catalog mistaken or omitted correct information. Packard’s catalog says right below 100 & 130 mm Dovetail jaws: “Both of these jaws should only be used on the SN2 chuck.”
Folks at Packard are woodturners so would not have a problem asking if they knew something Teknatool doesn’t.
Yes one of biggest feature of Nova chucks is jaw compatibility. Looking at G-3 page has this caveat “Common Accessory Jaw Fixing Profile – compatible across all NOVA chucks and accessories.” Looking at 100mm jaw compatibility page says same thing you posted.
http://www.teknatool.com/products/Chuck_Accessories/100mm.htm
Perhaps once get your new SN2 chuck & 100mm jaw set will tell us how well that jaw set works on a G-3.
-- Bill
