Router Bits: Straight vs Rabbet vs Dado
Forum topic by Broooklyn posted 03-05-2010 12:38 AM 7482 views 0 times favorited 6 replies Add to Favorites Watch
View Broooklyn's profile
Broooklyn
51 posts in 3010 days
03-05-2010 12:38 AM
I’m shopping for my first router bits and I’m looking for straight bits. It seems to me, with a fence and depth adjustments, I can also cut dadoes and rabbets with a straight router bit. So what’s the advantage to having bits specifically for rabbets and dadoes?
-- Matt - Brooklyn, NY
View Bill White's profile
Bill White
4901 posts in 3923 days
#1 posted 03-05-2010 12:43 AM
Straight bits will work just fine when used with a straight edge attachment or table. You can buy 4 gazzilion different bits to do 8 gazzilion jobs if ya have 30 gazzilion dollars.
Are you using a table? Have you gotten a good book about router use?
Bill
-- bill@magraphics.us
View LeeG's profile
LeeG
40 posts in 2983 days
#2 posted 03-05-2010 01:04 AM
The only real advantage of using a rabbeting bit vs a straight bit is repeatability. If you are doing all of your cuts at the same time, that doesn’t matter. I would make a rabbeting bit a low priority if I already had a table mounted router. If you have one, you can easily repeat a depth of cut if you need to add another board later.
-- Lee in Phoenix
Broooklyn
#3 posted 03-05-2010 02:26 AM
I don’t have a table yet, so I’ll routing by hand. I don’t have a book on routers but I’ve watched a lot of videos and read a lot stuff online.
View skone's profile
skone
147 posts in 2768 days
#4 posted 02-20-2011 09:33 PM
matt, what did you end up doing? i’m setting up my first router and looking for my first bits now. routing dados by hand with a straight edge. if i wanna fit 1” (3/4) stock into the dado groove – what measure should the bit be? i’ve seen some “reduced” size bits for 3/4 plywood and not sure if that’s what i need….
-- "Take extra care not to lose what you feel" (Winwood/Capaldi/Wood)
View richgreer's profile
richgreer
4541 posts in 3037 days
#5 posted 02-20-2011 09:55 PM
I sometimes use my router for dados and rabbets but my first choice is to use the table saw with a dado stack.
IMO – a dado stack leaves a cleaner cut and is more versatile.
View ND2ELK's profile
ND2ELK
13495 posts in 3736 days
#6 posted 02-20-2011 10:15 PM
If you are going to rout a lot of dados and rabbits for plywood you might want to buy a set of plywood router bits that is designed for todays undersized plywoods. I prefer using my dado heads like Rich but a lot of people prefer using a router and straight edge.
-- Mc Bridge Cabinets, Iowa
