Aluminium work?
Forum topic by ZeroThreeQuarter posted 03-04-2010 11:58 PM 1405 views 0 times favorited 10 replies Add to Favorites Watch
View ZeroThreeQuarter's profile
120 posts in 2990 days
03-04-2010 11:58 PM
Topic tags/keywords: aluminium question finishing
Has anyone here by chance worked with Aluminium before? I got some scrap pieces that i’m contemplating using in a bench, but i don’t know much about it other then cutting it and getting it welded by a friend of mine. I’m looking for info on how to either clean it up or buff it. I’ll be taking a picture of it later today when i pick up the pieces. They’re all C-channel style pieces, about 2” x 4” and 1/8” or so thick.
Thanks ahead of time.
-- Your mind, much like a parachute, works best when open.
10 replies so far
View KayBee's profile
1083 posts in 3179 days
#1 posted 03-05-2010 12:06 AM
Welding it is supposed to be difficult-I’m not a welder. But I do know that bolting aluminum channel together will is pretty solid.
-- Karen - a little bit of stupid goes a long way
View GaryK's profile
10262 posts in 3921 days
#2 posted 03-05-2010 12:12 AM
The problem will be oxidation after it’s cleaned up. You will either need to paint it, anodize it, of keep a coat of oil on it.
You can cut it will most woodworking tools (no jointer or planer).
View Bill White's profile
Bill White
4878 posts in 3893 days
#3 posted 03-05-2010 12:16 AM
There are as many alum. alloys as there are for many othere metals. Some soft, some hard. Gotta be sure what you’re workin’ with to determine the correct application.
#4 posted 03-05-2010 12:26 AM
thanks Bill, I kinda had a feeling that would be the case. The cutting and welding isn’t my big problem, it’s the final finish/application that’s my issue.
Gary – What kind of oil would be used if unpainted or not anodized?
View jm82435's profile
1285 posts in 3675 days
#5 posted 03-05-2010 01:53 AM
As Gary said, you can cut it with your woodworking tools. (I would recommend a band saw). Also as said if it has been sitting around, oxidation and impurities can be a big problem when you try to weld it. A wire brush finish looks nice, you can also sand and polish it (buff it with polishing compound). Just how good do you want it to look?
-- A thing of beauty is a joy forever...
View BradHess's profile
63 posts in 2945 days
#6 posted 03-05-2010 02:24 AM
We used to use simichrome to polish custom made bike frames made out of aluminum at a past job. We then powder coated them, however I know that before I started their they used to just polyurethane them to protect them. The only reason they switched to power coat was the polyurethane did not hold up to UV as well.
View jayjay's profile
639 posts in 2979 days
#7 posted 03-05-2010 03:03 AM
More than likely it’s probably 6061 aluminum, ER4043 filler would would fine to weld it up with GTAW process. If you plan on anodizing the part after welding, 5356 filler might be a better choice for its color matching properties. However, if you’re going to paint or powder coat, I’d go with the ER4043, as it has better wetting action for welding. Stainless steel wire brush and wipe down with alcohol prior to welding. If the scale is thick, sand down with a silicone carbide sanding disc first, then SS brush, alcohol. Try to stay away from scotchbrite for precleaning applications, because it contains aluminum oxide as an abrasive, and aluminum oxide is what you’re trying to remove in the first place. After welding, scotchbrite is an excellent choice to polish up the metal and weld area. If other than just for visual asthetics, a simple buff and polish with scotchbrite would be plenty. There isn’t any real need to cover it up with anything unless it was going to be exposed to the weather.
-- ~Jason~ , Albuquerque NM
View UrbaneHillbilly's profile
22 posts in 2983 days
#8 posted 03-05-2010 03:20 AM
One thing you can do to hold a shine and avoid oxidation is shoot it with some automotive clear coat. I have a bike that was stripped down to aluminum and after a good polish we used auto clear on it. I was worried it wouldn’t hold on a shiny polish but it did.
View bigike's profile
4053 posts in 3221 days
#9 posted 03-05-2010 03:58 AM
put a buffing wheel on the grinder and go to town with any compound u got i did this at my work and used compound that is for buffing acrylic and my handles came out great then shot them with some laq. for the finnish plus to keep them shinny.
-- Ike, Big Daddies Woodshop,
View Glen Peterson's profile
Glen Peterson
556 posts in 2989 days
#10 posted 03-05-2010 04:09 AM
You might want to take a look at past issues of Shop Notes. There are lots of projects in the issues that include working with aluminum. Many of the uses or aluminium are to reinforce corners, but it might be useful. Unfortunately I don’t know how to access them other than looking in the actual magazines. Like Wayne says, the nice thing about aluminium is that it’s soft enough that it can be cut, drilled, and shaped with woodworking tools.
-- Glen
