Opinions on attaching top 'frame' to table base
« back to Joinery forum
Forum topic by JasonZahn posted 03-17-2016 01:06 AM 541 views 0 times favorited 4 replies Add to Favorites Watch
View JasonZahn's profile
JasonZahn
56 posts in 1281 days
03-17-2016 01:06 AM
I’m looking for some opinions as to what might be the best way to attach the top to the base of a coffee table I’ve been working on. As you can see in the pic, the top is like a frame, and will have 2 glass panels inset when it’s finished. Originally I was thinking of attaching the ‘rail’ at the rear of the table to the rear apron via two figure 8 type ‘desk fasteners’ and the front ‘rail’ of the top to the upper rail of the table (above the drawer openings) with a couple of screws in elongated holes. Does anyone see an issue with this since, or is there a better way to do it? I guess I’m concerned with forces from wood movement, but maybe I’m overthinking it since both sides of the top will be finished equally? Any help is appreciated!
View DirtyMike's profile
DirtyMike
637 posts in 926 days
#1 posted 03-17-2016 01:12 AM
Great work man, you almost made me like coffee tables again.
View TarHeelz's profile
TarHeelz
59 posts in 2105 days
#2 posted 03-17-2016 02:53 AM
I would just use figure 8s. They move around plenty.
-- Tar Heelz, Durham, NC USA
View Aj2's profile
Aj2
1426 posts in 1822 days
#3 posted 03-17-2016 03:20 AM
I wouldn’t worry about expansion and contraction too much.Each board is independent of each other so movement will be small.Its kinda like each board is a separate table top.Fasten away.
-- Aj
JasonZahn
#4 posted 03-17-2016 11:57 AM
Thanks guys, I appreciate the input. I’ll just go forward with what I had planned.
DirtyMike- thanks…as much time as this table has taken me, I’m beginning to dislike coffee tables myself!
