03-16-2016 05:09 PM
I’m working on a pair of 60 inch birch dovetailed hopechests.
The high gloss is turning out to be a major challenge in a dusty old shop!
THE PROBLEM: I thought I had the answers for removing the dust nubs and re attaining the high gloss mirror sheen, but…. Nope. Dang!
So far it is Birch sanded to 220, conditioned, stained twice with oil MINWAX, and given three coats of HIGH GLOSS oil based varethane with 400 grit standings between coats. A lame YouTube video convinced me I could retain the sheen with buffing a non-silicone carnuba based car polish after 600, 1000 and 2000 wet sands.
After the varethane solidified I went to work testing my methods on an unimportant rear.
The poor results: A satin finish of slightly creamed fade, and small spots of high gloss reflection despite a very flat uniform surface.
The question: My remaining high gloss sides – covered in dust nubs: How can I remove the nubs while keeping the high gloss mirror sheen?
Just waiting to learn to add photos, hold on a minute :)
Thanks for any expertise!
Ben Scholten
9 replies so far
#1 posted 03-16-2016 05:13 PM
I know this isn’t what you want to hear, but the rubbed out finish looks way better than the high gloss! I wet sand my final coat with water and a 1500 grit soft sponge. But then again, I am going for a satin finish from the start.
Read up on french polishing if you truly are set on the high gloss look.
#2 posted 03-16-2016 05:20 PM
Just about anything that will remove the nibs will also mar the sheen. You might try just some brown crumpled up paper (grocery bag/kraft paper). The problem with using it is the finish will have to mostly cured, and with an oil based varnish that may take a few week. But that may also be part of the problem you now have; the relatively soft uncured finish will get very fine scratches that reduce the sheen. If you have a piece to est this on, it may do what you want: wet sand out the nibs with the finest paper you have, dry it thoroughly. Then apply a coat of wiping varnish with a cloth….this would be your Varathane with about 50% mineral spirits added. It may give you the gloss appearance (which I like) and then tack up fast enough that nibs are not a problem (TEST it first).
#3 posted 03-16-2016 05:45 PM
Wet sand to 1000 or higher, then use these buffing compounds with a good wool buffing pad. Do a final buff with a foam pad. It’s a lot of work, but that’s the way to do it if you want it right. You could probably skip step 3 and finish with the swirl remover. I always put the compound on the pad and rub it in, then sprinkle a little water on the top before I start. You don’t want to get the finish too hot while your buffing. Wear a good bib because it gets messy.
 Final buff:
#4 posted 03-16-2016 06:08 PM
High gloss finishes are a pain to get right.I agree with others rub it out till you get a even sheen you like. Also remember your piece will look much better inside under differant lights. So if it looks good under your shop lights its gonna look great inside the house I hope I hope.
-- Aj
#5 posted 03-16-2016 06:35 PM
Stop what you’re doing and let it sit for 2 weeks before you do anything else. Then wet sand and polish.
-- TruCraftFurniture.com
#6 posted 03-16-2016 08:16 PM
I think my largest root problem was not waiting long enough for the oil varethane to cure. I’ll give it 2 more weeks.
The 3M compounds together are $200 bucks! (Canadian) Are there any other options and compounds on the cheaper end? The chests are a gift.
When I begin again, should I omit 600 grit, and should I go to 2000 grit?
Thanks so much for all the help so far, there’s a ways to go yet!
Ben Scholten
#7 posted 03-16-2016 08:28 PM
Yeah, the finish needs to cure real good. The harder the finish the better to buff. You don’ have to buy the 3M, just get a good automotive rubbing compound. Give it a shot. If your a good buffer, that’s all you might need. I would start with 1000 and see if it takes it down to flat enough for you. Depends how rough the finish is and how deep the marks you need to get out are. If 1000 works there’s no need to try to sand out the 600 grit scratches, but that’s just my opinion. A lot of people think you need to start low and go through every grit. I only start as rough a grit as I need to to get blemishes out.
Can you get Meguiar’s? This is a good one that may work for you as well.
#8 posted 03-16-2016 10:45 PM
French polish will get you the best gloss but your surface has to be perfect or it will show. FP can be applied over what you have or just about any other finish and will definately get you the gloss you want.
#9 posted 03-16-2016 11:54 PM
I agree on the polish approaches. I use pumice stone, rotten stone, then McGuires on pads powered by my variable speed ROS (Porter Cable).
Before
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12027 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2105 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
431 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
340 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1370 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
4902 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
6691 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
28044 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
211 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5404 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1417 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6231 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1387 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2153 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1186 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
4754 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2200 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
8844 |
