finishing purple heart problem
Forum topic by Mike posted 03-04-2010 08:56 AM 1474 views 0 times favorited 7 replies Add to Favorites Watch
View Mike's profile
Mike
93 posts in 3313 days
03-04-2010 08:56 AM
Topic tags/keywords: question purpleheart finishing
I built a box out of purple heart with with maple corner keys or feathers and whene I put the clear finish on (wipe on poly) I have white showing in the grain. Seems to be sanding dust that wouldn’t come out. I vacumed and wiped and used a damp cloth but still had white in the grain.
Really frustrating as it’s not real attractive. Any ideas on what I did wrong.
Thanks for the help.
Mike
-- Mike, Cantral Oregon
7 replies so far
View Eagle1's profile
Eagle1
2066 posts in 3213 days
#1 posted 03-04-2010 12:53 PM
Purple Heart is a very hard wood. Go back and start with about 80 grit and then up..
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
View richgreer's profile
richgreer
4541 posts in 3223 days
#2 posted 03-04-2010 03:22 PM
Blast it with a shot of air from an air compressor at 80 or higher psi.
View Bob42's profile
Bob42
456 posts in 3939 days
#3 posted 03-04-2010 03:46 PM
You might have raised the grain with the damp cloth and when you apply your finish the fibers is what you are seeing. I would re-sand, then before I apply my finish I always use a tack cloth with light pressure. Also make sure it’s not coming from the cloth. Try a sample piece first. I hope this helps.
-- Bob K. East Northport, NY
View Mike's profile
Mike
#4 posted 03-04-2010 06:39 PM
I had read about useing mineral spirits on a wipe rag on a dust removal post recently. Does that raise the grain?
TopamaxSurvivor
18373 posts in 3824 days
#5 posted 03-04-2010 07:23 PM
I don’t think mineral spritis will, but water definitely will.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3629 days
#6 posted 03-04-2010 09:40 PM
Hey Mike…is the white in the grain all over the piece, or is it mainly near the corners? I was wondering if you might have yellow glue in the grain from the glue up.
-- Wayne - Plymouth MN
View Mike's profile
Mike
#7 posted 03-04-2010 10:07 PM
no it’s not glue. Its all over.
