Craftsman radial arm saw won't reset!
Forum topic by thebigmuddy posted 03-16-2016 09:09 AM 1583 views 1 time favorited 7 replies Add to Favorites Watch
View thebigmuddy's profile
thebigmuddy
53 posts in 960 days
03-16-2016 09:09 AM
Topic tags/keywords: question
I was using my raial arm saw and it kicked out, this has happened before and I just hit the reset button and after it
rests for a while it always restarts, not this time though. Anyone else have this issue? Is there anything I can do, take the motor apart, smack it with a 2×4, or I am just SOL?
-- The craftsman is his own harshest critic... Jeff (me)
7 replies so far
View dhazelton's profile
dhazelton
2789 posts in 2416 days
#1 posted 03-16-2016 12:55 PM
Dumb question, but you checked the circuit breaker?
If it has a thermal overload switch that won’t reset the switch is probably bad. You would have to bypass it to find out if it is truly the switch or the motor itself. If you didn’t let the smoke out my money is on the switch or the wiring to it.
View conifur's profile
conifur
955 posts in 1271 days
#2 posted 03-16-2016 01:07 PM
Do you have it plugged into a power strip? If so check that.
View Cooler's profile
Cooler
299 posts in 962 days
#3 posted 03-16-2016 02:00 PM
Is this one of those digital models? Mine had a capacitor that burned out. It was expensive from Sears but very cheap from Graingers. The installation was fast and easy.
-- This post is a hand-crafted natural product. Slight variations in spelling and grammar should not be viewed as flaws or defects, but rather as an integral characteristic of the creative process.
View Handtooler's profile
Handtooler
1626 posts in 2251 days
#4 posted 03-16-2016 05:53 PM
I own and use a Craftsman 10” RAS from 1978 that trips this over heat button/switch on the motor housing when sawing extra heavy hard woods occasionally and takes about 4-5 minutes to cool then will reset, however on a few occasions it had also tripped the 20A circuit breaker on the panel board. Please try resetting both and unplug and replug the cable. it won’t cost ya but an extra minute. I am anxious to hear your results for a fix.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View JoeinGa's profile
JoeinGa
7739 posts in 2126 days
#5 posted 03-16-2016 06:27 PM
Wouldn’t hurt to blow out the motor. switches, and any where you can with compressed air. The buildup of sawdust will contribute to over heating.
thebigmuddy
#6 posted 03-17-2016 11:22 PM
Okay, the circuit is okay, blew out the dust, etc., finally I removed the switch, destroying it in the process. I expected to find two wires that I could connect and be back in business, but instead I found four wires… not sure where to go from here. Any ideas?
MrUnix
6889 posts in 2318 days
#7 posted 03-18-2016 02:34 AM
Most likely a DPST switch since the machine can be wired for either 120 or 240v.
