How to scale objects
Forum topic by packetsmacker posted 03-15-2016 05:28 PM 957 views 0 times favorited 14 replies Add to Favorites Watch
View packetsmacker's profile
packetsmacker
31 posts in 2314 days
03-15-2016 05:28 PM
Is there a good way to scale objects so you can maintain proportions?
Examples would be a symbol or a hammer. Suppose I wanted to make a 3’ tall hammer but maintain the correct proportions. Or if I found a symbol doing a google image search how would I make that lager?
I have searched all of google and cant find an example.
14 replies so far
View MadMark's profile
MadMark
979 posts in 1354 days
#1 posted 03-15-2016 07:53 PM
Its called magnification. You can do it on a computer or with a pantograph.
View shipwright's profile
shipwright
7892 posts in 2699 days
#2 posted 03-15-2016 10:06 PM
You mean a symbol like this?
Harder for a physical object but for an image a vector graphic program like Inkscape will scale up or down without changing line thickness.
View ChefHDAN's profile
ChefHDAN
1010 posts in 2751 days
#3 posted 03-15-2016 10:10 PM
I’ve used the scale tool in sketch up with some success when drawing projects, have to get better with my components but usually can get the numbers to do what I want, when I re-size a top or a face frame etc.
View Jim Finn's profile
Jim Finn
2612 posts in 2823 days
#4 posted 03-15-2016 11:07 PM
I scale up images from the internet using “Paint” which is in Microsoft.
View lew's profile
lew
11939 posts in 3657 days
#5 posted 03-15-2016 11:50 PM
Insert the JPEG image into Microsoft word and then resize the image by dragging one of the corner “handles”.
View SenecaWoodArt's profile
SenecaWoodArt
402 posts in 1521 days
#6 posted 03-16-2016 04:31 AM
I use Photoshop. You can query the size of the image in inches for this case and then tell it to resize to whatever size you need. I often resize to larger than my printer can handle, so I crop the image into multiple parts that I can print and then overlay them to get the pattern I need. It is my understanding that you can do this with Inkscape as well and Inkscape is a free program
-- Bob
View Rick_M's profile
Rick_M
11077 posts in 2281 days
#7 posted 03-16-2016 05:14 AM
Old school by using a grid, a pantograph, an overhead projector; new school is woodgears big print.
-- http://thewoodknack.blogspot.com/
packetsmacker
#8 posted 03-17-2016 02:08 PM
Thanks for all the info. I will have to try it out later today.
packetsmacker
#9 posted 03-17-2016 02:33 PM
Ok looks like I should be able to use GIMP to scale up my project. I can’t print it out at work so I will have to wait till I get home. Thanks again for the suggestions.
View waho6o9's profile
waho6o9
8098 posts in 2478 days
#10 posted 03-17-2016 03:09 PM
Proportional dividers?
Rick_M
#11 posted 03-17-2016 06:16 PM
View bearkatwood's profile (online now)
bearkatwood
1476 posts in 913 days
#12 posted 03-17-2016 06:21 PM
I have a cheap overhead projector that I have used on some jobs. It came in handy when a person sent me a picture of the table they wanted built, but no dimensions. I was able to mark out the height I wanted on a piece of paper and then project the picture of the table leg and play with the image until it just fit the measurements. Then I had a pattern to use for the legs.
-- Brian Noel
View CaptainSkully's profile
CaptainSkully
1565 posts in 3460 days
#13 posted 03-19-2016 02:16 AM
If the final image fits within an 8.5×11 rectangle, I paste the image in question into Word. Then click the image and grab the corner to stretch the box to the correct size. Sometimes you have to hold the Shift key to maintain the proportions.
-- You can't control the wind, but you can trim your sails
packetsmacker
#14 posted 03-19-2016 11:45 AM
Using inkscape worked. I had to save it as a pdf then when printing it as a pdf you have to select titled printing ( or something like that I am not looking at it at the moment)
