Since when did plywood go metric?
Forum topic by MrRon posted 03-15-2016 03:51 PM 1192 views 0 times favorited 16 replies Add to Favorites Watch
View MrRon's profile
MrRon
4793 posts in 3266 days
03-15-2016 03:51 PM
I was building a closet organizer and measured the thickness of 3/4” (top choice from Lowes) plywood with a micrometer. It measured .710”. 18 mm =.7087”. This is totally unacceptable for 3/4” plywood. If you use an undersize router bit to cut dados, the dado is still too large as the bit is only 1/32” (.032) undersize. The thickness of the plywood is .040” less. This has caused problems when designing projects. When you assume the plywood is 3/4” (.750) thick and you make your cut, you end up with a dimension that is not what you wanted. I am fortunate that I can layout my work using Autocad. I can draw everything taking into account the actual thickness of the material.
16 replies so far
View Pezking7p's profile
Pezking7p
3217 posts in 1674 days
#1 posted 03-15-2016 04:02 PM
Just the way of plywood I guess. I’ve gotten used to it. It’s one of the reasons I cut plywood dados with a dado stack instead of a router. An exact size dado jig would be even better.
-- -Dan
View jmartel's profile
jmartel
7951 posts in 2172 days
#2 posted 03-15-2016 04:06 PM
It hasn’t been a full 3/4” for many years now. Use an exact width dado jig as was said.
MrRon
#3 posted 03-15-2016 04:38 PM
It hasn t been a full 3/4” for many years now. Use an exact width dado jig as was said.
- jmartel
I realize that, but it was always 1/32” less in thickness. Router bit makers made bits that were 1/32” less to match the plywood. This “metric” plywood is still smaller yet. The only way to cut dados is with a dado stack set or a smaller router bit and a jig.
View WhoMe's profile
WhoMe
1564 posts in 3266 days
#4 posted 03-15-2016 04:43 PM
Ahh, more perils of being one of only 2 countries still not on the metric measuring system.
Personally, I think it is the manufacturers trying to squeeze out as much wood without actually going down a physical size in plywood thickness
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
View Ger21's profile
Ger21
1074 posts in 3153 days
#5 posted 03-15-2016 04:54 PM
If you bought enough sheets, I think that you’d find that the thickness can vary by more than .01”
I’ve done jobs with 100+ sheets, and found that dados that fit with the first 40 sheets were much too small on the next bundle.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View LiveEdge's profile
LiveEdge
585 posts in 1642 days
#6 posted 03-15-2016 04:54 PM
Was it birch plywood? That traditionally comes in mm because it comes from Northern European countries.
View sepeck's profile
sepeck
342 posts in 2163 days
#7 posted 03-15-2016 04:59 PM
Random from memory the Wood Whisperer had an exact width dado jig.
http://www.thewoodwhisperer.com/videos/exact-width-dado-jig/
I have seen ads for router bits sized for these, but yet another investment and I don’t have any.
-- -Steven Peck, http://www.blkmtn.org
View b2rtch's profile
b2rtch
4861 posts in 3071 days
#8 posted 03-15-2016 05:07 PM
I have a set of undersized router bits from Freud just for this reason
-- Bert
View hotbyte's profile
hotbyte
991 posts in 2998 days
#9 posted 03-15-2016 07:09 PM
I think MrRon is saying he now needs an undersized, undersized bit :(
- b2rtch
View bbasiaga's profile
bbasiaga
1234 posts in 2017 days
#10 posted 03-15-2016 08:40 PM
- b2rtch
- hotbyte
Or an oversized 18mm bit…. :)
View SignWave's profile
SignWave
440 posts in 3057 days
#11 posted 03-15-2016 09:07 PM
It’s been a long time since I’ve seen plywood marked as 3/4”. It always says 23/32. That would be .71875 which is pretty darn close to what you measured. Was it marked as 18mm?
-- Barry, http://BarrysWorkshop.com/
MrRon
#12 posted 03-17-2016 04:04 PM
It s been a long time since I ve seen plywood marked as 3/4”. It always says 23/32. That would be .71875 which is pretty darn close to what you measured. Was it marked as 18mm?
- SignWave
The plywood came from Lowes and labeled “Top choice”. It was stamped on the edge stating it was .710” thick. It has 11 plies, but the face layer is the thinnest I have ever seen on plywood.
View marshallLaw's profile
marshallLaw
17 posts in 822 days
#13 posted 03-18-2016 06:24 AM
MrRon, you answered your own question – the reason you see a difference is your buying source. The big box stores are buying bulk, lower quality plywood.
If you check regular, honest to god lumber yards you will find better quality 3/4” plywood measuring in at 23/32”. They are known for under selling which causes grief for customers coming in wanting us to price match them I gently inform them that we can ‘t price match because our quality is better.
View tomsteve's profile
tomsteve
790 posts in 1241 days
#14 posted 03-19-2016 11:55 AM
yer shopping for plywood at lowes and expecting cabinet grade quality maybe?
it is “top choice”..... for lowes.
ive been workin on afew projects with plywood from menards. not needing super high quality 13 ply for the projects, so menards ply will work.
i found the thickness in one sheet varied 1/32”.
View Logan Windram's profile
Logan Windram
346 posts in 2484 days
#15 posted 03-19-2016 01:41 PM
Buying stock from lowes was the biggest problem.
