Putting ductwork and pneumatic gates in the attic
Forum topic by Kelly posted 03-15-2016 12:44 PM 597 views 1 time favorited 7 replies Add to Favorites Watch
View Kelly's profile
Kelly
66 posts in 1681 days
03-15-2016 12:44 PM
Topic tags/keywords: dust collection
Hello LJ’s!
I’m hoping to get a little feedback on the pros and cons of moving my dust collection and operating pneumatic dust gates in an attic.
Originally I had hoped to put my DC duct work in the floor, however that didn’t work and I currently I have it mounted to the ceiling. This system works well but because I leave my DC continually running while I’m working in the shop, (the DC is in a separate room) there is the constant noise air leaking through the gates. Also, to avoid having ducts running through the middle of my ceiling I have everything running against the walls and some of the runs are a little long. Moving both the gates and the ducting to the attic would solve both problems allowing for more direct runs and the noise of the gates, not to mention all the additional tubing that would accompany a pneumatic system. As I have been considering changing all my gates, which are now controlled manually to a pneumatic system, I thought this might be a perfect opportunity to work change the location of all the ducting too.
I’m hoping to get some feedback on the pros and cons of going this route as well as any insights anyone might have on the pneumatic gates and issues I might encounter by going into the attic with both my ducting and gates.
Here is a short video clip of how I would like to automate the gates. The only difference would be that I’m going to use a current sensor which will open the gate when the tool is powered on rather than having a separate switch. https://youtu.be/482rR-3CmQU
Thanks and I look forward to hearing your ideas!
7 replies so far
View bigblockyeti's profile (online now)
bigblockyeti
4888 posts in 1593 days
#1 posted 03-15-2016 12:52 PM
My concern would be regarding accessibility for maintenance and clearing a clog if you were to experience one. Other than that I see no reason not to put everything in the attic, especially if it shortens the runs.
View rwe2156's profile
rwe2156
2749 posts in 1353 days
#2 posted 03-15-2016 01:05 PM
I leave my DC continually running while I m working in the shop
Why?
Anything you can do to increase the efficiency of the layout is worth it.
Personal choice, but for me, its much cheaper to just get in a habit of closing gates when I’m done at a machine.
Pretty neat, though.
View JoeinGa's profile
JoeinGa
7732 posts in 1879 days
#3 posted 03-15-2016 01:19 PM
I think the pneumatic gates would be a “Techie” kind of thing (such as I am also prone to liking ) but the main question I have is regarding placing the ducting in the attic. I’m wondering how much moisture the heat/cold cycles will cause to be in the pipes? When you’re pulling wood dust and small chips thru pipes, the LAST thing you want is the pipes to be damp. The buildup of “crud” would not take long at all.
4827 posts in 2366 days
#4 posted 03-15-2016 01:20 PM
I agree with yeti, the maintenance aspect would be a bummer. Maybe not with clogs (if you have a big DC) but there will be a time (guaranteed) that you will have to change something. It might be due to a tool change/upgrade, an additional tool, or you just want to rearrange things…but there will be changes.
View bonesbr549's profile
bonesbr549
1469 posts in 2940 days
#5 posted 03-15-2016 03:11 PM
As long as you don’t have leaks your fine, and don’t think it should be a problem. If you have a jam or something which I would doubt, you’d have to tear into it to fix, but if you have a way to access the area above the ceiling i.e. attic whats the issue?
Only thing I would suggest is you add a delay in closing your gates and cutting off the DC. Allow a little time to clear the line.
I went with the grngate system. I liked it because it’s modular and is electric but the gates are connected by eithernet cables that are off the shelf, so you can get them anywhere and any length. The gate motors are powered by the ethernet cables and you can chain them together so no special power wiring. They are controlled by a central unit. I also liked them because they were the only system I could find that had a sensor for three phase tools, which I needed.
I put the sensors on the tool and the gate senses power on, opens the gate turns the dc on and then when I cut the tool off, it waits about 10 sec’s to clear the line and shuts the gate and cuts off the DC. I love it. They also have a manual switch option that I use for the chop saw as you don’t want that thing causing the dc to go off/on all the time, so just turn it on and then off when you leave the station. I also liked the design of the gates to keep them from getting fowled.
I’m getting ready to add a cnc machine to the shop and will be adding one more gate and its a snap to do, I just ordered the gate/sensor and i’m in business.
I did a review here. If you already have all the investment in the pneumatic, then probably not for you, but I would add that delay
http://lumberjocks.com/reviews/3871
https://youtu.be/CUIQCs8o9AY
View JAAune's profile
JAAune
1772 posts in 2189 days
#6 posted 03-15-2016 03:23 PM
Don’t run drops straight down from the main. You need a small horizontal leg before dropping down. This prevents the drop from collecting a bunch of sawdust when the gate is closed.
View AZWoody's profile
AZWoody
1194 posts in 1096 days
#7 posted 03-15-2016 04:15 PM
Why?
- rwe2156
It’s actually better on the larger dust collectors to leave them running than to use them on and off as you use the tool approach. I was looking at putting an ivac switch to turn on my clearvue but after talking with them, I found that it could lead to early failure of the capacitors and the larger motors are designed for continuous run, rather than constant start/stop.
