Gravity Feed HVLP Spray Gun
Forum topic by John posted 11-28-2007 10:00 PM 1060 views 0 times favorited 2 replies Add to Favorites Watch
View John 's profile
John
100 posts in 4157 days
11-28-2007 10:00 PM
Hey Guys
Rockler has an HVLP 1.4 mm spray gun on sale and I have a question about it. What kind of compressor do you hook it to? It says it needs 15 to 50 PSI? Is this a rather small compressor? What would some of you recommend to meet this need? Any input would be greatly appreciated.
-- Thanks!
2 replies so far
View Alin Dobra's profile
Alin Dobra
351 posts in 4128 days
#1 posted 11-28-2007 10:20 PM
John,
The problem with conversion HVLP (the hvlp guns that connect to a compressor) is not the PSI requirements but the airflow requirements (CFM). A small compressor can easily put out 50PSI but can only get about 4CFM. Most guns would need 8-12 CFM.
For 100$ Rockler is selling an HVLP gun with turbine (included). I have it and it works great for shellac (probably polyurethane as well).
Alin
-- -- Alin Dobra, Gainesville, Florida
John
#2 posted 11-28-2007 10:25 PM
Alin
Thanks for the quick reply. This sounds like it might be the way to go. What model is it you are using? And, yes, I would be spraying quick-dry polyurethane – water based version.
-- Thanks!
