Manual for a Ridgid 2424-1 Needed and Tune up question
Forum topic by Forseeme posted 03-14-2016 09:17 PM 722 views 0 times favorited 4 replies Add to Favorites Watch
View Forseeme's profile
Forseeme
28 posts in 965 days
03-14-2016 09:17 PM
Topic tags/keywords: ridgid 2424 manual table saw question tablesaw
Hello – First post here (been lurking for last 6 months as I setup a “real” – for me – shop). I just purchased a used Ridgid 2424 Table Saw (based on many of the positive comments here), but am having trouble finding the manual. Links in various forum posts are dead, and I hesitate to pull from “manuals.com”. Anyone have a manual they can scan (or even better, already have it in pdf format)?
I plan on using the manual to tweak the blade alignment, as well as see how the saw should be setup (a part or two might be missing – like the rod that attaches the blade guard).
My second question is, the front rail has some scratches – OK to steel wool them off, or will I do more harm than good (you can feel the scratches when you run your hand on the rail).
Thanks for any help/suggestions!
View MrUnix's profile
MrUnix
6766 posts in 2222 days
#1 posted 03-14-2016 10:12 PM
http://www.manualslib.com/products/Ridgid-Ts2424-2937099.html
View toolie's profile
toolie
2134 posts in 2652 days
#2 posted 03-15-2016 04:20 PM
I plan on using the manual to tweak the blade alignment, as well as see how the saw should be setup (a part or two might be missing – like the rod that attaches the blade guard). there’s no rod that attaches the blade guard. there’s a bracket with a fitting that permits for removal and reinstallation without affecting it’s alignment. the 2424 also has two horizontal screws on the rear trunion support that can be used to sneak up on blade to miter slot alignment. be sure to use the same miter slot when aligning the fence to the miter slot. that saw, being gray in color, also carries a lifetime guaranty covering manufacturing defects regardless of who owns the unit.
My second question is, the front rail has some scratches – OK to steel wool them off, or will I do more harm than good (you can feel the scratches when you run your hand on the rail). ignore them. I have a souped up 2412, which is a level below the 2424 with the same fence. that fence can be tuned to be as accurate and repeatable as the much complimented delta T2.
- Forseeme
see above. its a great saw that can do whatever a hobbyist needs to do.
Forseeme
#3 posted 03-17-2016 01:11 PM
MrUnix – I had seen that link, but was a bit spooked to use it. I work in IT, so opted to pull the file down from another users machine (and now they suffer with an additional browser toolbar) – but I got the manual, so thanks.
Toolie – Thanks for the tips. I will ignore front rail scratches. Right now it is all in pieces. Once I clean it, dry lube everything, and get it all back together, your comments on the guard will probably make more sense to me (and I will have the manual for help).
Possible stupid question: What is the hole for in front of the blade? I assume it had a cover on it at some point.
I forgot to ask about blade wrench when I purchased it – hopefully something I have kicking around will fit.
toolie
#4 posted 03-17-2016 04:19 PM
- Forseeme
the hole in front of the blade is for a plastic disk onto which i line can be scribed to represent each side of the blade as an alignment aide for crosscutting. i’ve never used either of mine ( i have a similar c-man and a 2412.
