Bandsaw Zero Clearance Insert for Grizzly
Forum topic by Padre posted 03-03-2010 01:47 AM 6197 views 0 times favorited 12 replies Add to Favorites Watch
View Padre's profile
Padre
930 posts in 3689 days
03-03-2010 01:47 AM
I have a G0513X2 – 17” Bandsaw, and I need a new insert as well as a zero clearance insert. It is 2.75”OD. Does anyone know where I can get one? I called Grizzly and they said go to carterproducts.com, but I can’t find one there either. Thanks.
-- Chip -----------http://www.penmanchip.com-----------------Micah 6:8
12 replies so far
View NBeener's profile
NBeener
4816 posts in 3374 days
#1 posted 03-03-2010 03:09 AM
I was just figuring I’d have to buy some UHMW stock, and make my own, for my G0555X.
If you get bored enough, you could ping them, and see what they might be able to suggest….
http://www.carterproducts.com/service_contact.asp
If you DO get any news … it’d be great if you could update this thread :-)
-- -- Neil
35148 posts in 4601 days
#2 posted 03-03-2010 04:30 AM
Turn one on a Lathe, You looking for metal or wood?
I also saw people just cut a piece of plywood and put it on the top if they ar planning to do some ripping. If you are using a crosscut sled, then you are out of luck with that suggestion.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Appomattox Virginia karsonwm@gmail.com †
Padre
#3 posted 03-03-2010 04:38 AM
I emailed them. I will update this thread when I hear back!! Thanks Neil.
Padre
#4 posted 03-03-2010 09:07 PM
Update: Just got this email from Carter Products:
Chip,
Thank you for the inquiry.
The insert sizes we offer are 2.5” diameter either for the Jet or the Delta. Unfortunately, not for the Grizzly.
Questions please let me know.
Regards,
Kristina Moore
Customer Sales & Service
Carter Products Company, Inc.
Toll free 888-622-7837
Padre
#5 posted 03-04-2010 03:06 AM
Another question: couldn’t I just take a 2.75” hole saw and cut a hole out of a 1/16th piece of sheet metal for my zero clearance insert?
View JasonC73's profile
JasonC73
49 posts in 2745 days
#6 posted 01-04-2012 06:19 AM
I have the same saw. I cut a piece of aluminum to rough shape, sanded it to shape, then cut a slot with a hacksaw…I tried to start the slot with the blade running on the bandsaw, but I got scared.
View Lee Barker's profile
Lee Barker
2170 posts in 3051 days
#7 posted 01-04-2012 07:09 AM
Aluminum, masonite (hardboard), even plywood will work. It can be thicker than the ledge, you just have to thin it out at the rim (router table job).
I have a lot of hole saws, so I would find one whose waste was closest to what I need, use that to cut the disk, and then sand it to the right diameter.
Kindly,
View Howie's profile
Howie
2656 posts in 3123 days
#8 posted 01-04-2012 02:59 PM
I have a GO555X. I also have a ridgis spindle sander that the washers for it are exactly the same size as the inset in the BS. I make mine out of hardboard and if it is a little thin I use a piece of duct tape on the back. Works good lasts a long time.
You could look in the hardware section at the local big box for a large washer the same O.D.
-- Life is good.
View gfadvm's profile
gfadvm
14940 posts in 2890 days
#9 posted 01-05-2012 05:37 AM
I cut mine out of plexiglass for my Grizz 17”
View PapaOso49's profile
PapaOso49
2 posts in 456 days
#10 posted 09-13-2017 03:01 AM
You can find them here. Found this guy on eBay. I bought one and it worked really well. They are made from Delrin. I was and am very pleased with the insert.
http://www.ebay.com/itm/182762035783?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2648
PapaOso49
2 posts in 456 days
#11 posted 12-16-2017 02:09 PM
I was just figuring I d have to buy some UHMW stock, and make my own, for my G0555X.
If you DO get any news … it d be great if you could update this thread :-)
This is where I purchased mine. I have the same bandsaw as yours.
https://www.ebay.com/itm/182762035783?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
- NBeener
View pmurray's profile
pmurray
1 post in 1286 days
#12 posted 11-16-2018 10:08 PM
Just to add my two cents worth. Rikon makes inserts that are 2.75” for their saws, but they work in the Grizzly 17”. I have one, I use them and have had no issue with them.
