Coplanar: your Bandsaw wheels not only aren't, they're not supposed to be
Forum topic by CharlesA posted 03-14-2016 01:34 PM 3460 views 0 times favorited 11 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3351 posts in 1996 days
03-14-2016 01:34 PM
I re-watched the famous Alex Snodgrass bandsaw video again just to remind myself before I adjust my bandsaw again, and I picked up something I had ignored before: his argument that bandsaws are designed not to have coplanar wheels and no one should adjust them to be coplanar because they become way more difficult to adjust. Seems like I regularly read about folks trying to make their wheels coplanar. Interesting that he begs folks never to adjust the wheels. One more thing off my to-do list.
11 replies so far
View Logan Windram's profile
Logan Windram
347 posts in 2660 days
#1 posted 03-14-2016 02:02 PM
There is more lore regarding coplaner wheels than anything else in WW. The tracking function on the saw adjusts for any inaccuracies in the tires, weld and wheel alignment. Because of that tracking function, the wheels will theoretical never be coplaner, so it’s a exercise in futility. The same thing with drift… I have seen people post about eliminating draft by adjusting this and that on the saw, but really it’s a simple fence adjustment. We overthink a lot of things in the shop, but it helps to pull back and realize these machine are simple in premise and set-up…
CharlesA
#2 posted 03-14-2016 02:09 PM
According to Snodgrass, if you did get them coplanar, any tiny mis-adjustment would lead to the blade running off the wheels. then again, he says if you have drift, you set your saw up incorrectly and that no bandsaw should have drift.
View Bill White's profile
Bill White
5121 posts in 4158 days
#3 posted 03-14-2016 02:49 PM
Ah, the land of coplanar. It is on the map right next to Oz and Shangrila. Folks who live there always sharpen their plane irons to a 20,000 grit nanonuclear dimension to achieve submicron shavings, measure wood cuts to within .0005”, and never, NEVER get splinters.
I’m gonna move there one of these days.
Bill
-- bill@magraphics.us
View jbay's profile
jbay
2859 posts in 1097 days
#4 posted 03-14-2016 02:57 PM
Ah, the land of coplanar. It is on the map right next to Oz and Shangrila. Folks who live there always sharpen their plane irons to a 20,000 grit nanonuclear dimension to achieve submicron shavings, measure wood cuts to within .0005”, and never, NEVER get splinters. I m gonna move there one of these days.
Bill
- Bill White
You could share a place with madmark!
Gerald Thompson
1117 posts in 2433 days
#5 posted 03-14-2016 03:28 PM
I tried everything, or so it seemed, then I went by Snodgrass’ instructions and now I only have operator error.
-- Jerry
View pintodeluxe's profile
pintodeluxe
5798 posts in 3011 days
#6 posted 03-14-2016 03:31 PM
I have seen his presentation at the woodworking shows, and a lot of it is good information. I think not fighting coplanar makes sense.
The “no blade drift” concept only works for me while my blade is razor sharp, which is about 3 days when resawing white oak. After that, I think my bandsaw truly cuts better allowing for its natural inclination to drift. Maybe if you have access to a carbide tipped blade it would be easier. Your results may vary.
View Jim Finn's profile
Jim Finn
2686 posts in 3120 days
#7 posted 03-15-2016 02:06 AM
- pintodeluxe I had trouble with “Drift” and I re-saw a lot. I found what works best for me is sharp blades. I use carbide blades and I re-sharpen them. I use a fixed re-saw fence (not adjustable) and when the blade starts to wander I re-sharpen it using a Dremel type tool. Takes ten minutes.
-- No PHD just a DD214 Website> craftingcouple.com
View bearkatwood's profile
bearkatwood
1663 posts in 1210 days
#8 posted 03-15-2016 02:22 AM
Very interesting conversation, thanks for the info CharlesA.
-- Brian Noel
View Redoak49's profile
Redoak49
3661 posts in 2187 days
#9 posted 03-15-2016 11:00 AM
Not only is Snodgrass entertaining but is correct. I have used a bandsaw a lot and finally watched his video and set up my bandsaw as he suggests. Wow…it runs great now.
View Tennessee's profile
Tennessee
2893 posts in 2712 days
#10 posted 03-15-2016 11:35 AM
+100 for Snodgrass.
First time I ever watched his videos, (quite a while ago), I was amazed at how out of position my bandsaws were.
Now, if I have drift, it is my signal that my blade is starting to dull, not because the saw is set up wrong.
And ironically, on my big Grizzly, I can push a dull blade a long time if I am careful and cut slowly.
View JoeinGa's profile
JoeinGa
7739 posts in 2205 days
#11 posted 03-15-2016 01:55 PM
Bill
- Bill White
Now THIS, made me laugh out loud !
