Dado Set Depth: 6" vs. 8"
Forum topic by BreakingBoardom posted 03-03-2010 12:02 AM 14820 views 0 times favorited 17 replies Add to Favorites Watch
View BreakingBoardom's profile
BreakingBoardom
615 posts in 3050 days
03-03-2010 12:02 AM
Topic tags/keywords: dado saw blade 6 8
I was just curious, what is the max cut depth for a 6” dado blade and an 8” dado blade? I was thinking of purchasing one and wondering if I really need to spend the money on the 8” set. Any thoughts on size and which dado sets work for you?
-- Matt - http://breakingboardom.wordpress.com/
17 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3037 days
#1 posted 03-03-2010 12:08 AM
It will depend on how high you can raise the blade and still turn the cutter. Offhand, I would guess that a 6” cutter would cut 2” deep (or less). An 8” cutter would give you 1” more depth.
View Jeison's profile
Jeison
968 posts in 3076 days
#2 posted 03-03-2010 12:09 AM
IIRC, you get about 1.5” depth from a 6” set and about 2.5” from an 8”. For typical projects a 6” should suffice. Also depends on your saw, many benchtops don’t have the power to handle the mass of an 8” set without straining. Some people also say that the extra mass in an 8” helps to leave cleaner cuts. Don’t have my practical experience with dado sets myself so can’t give much more help than that.
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
Sawkerf
#3 posted 03-03-2010 12:22 AM
Not only do many of the benchtops lack the power for a dado cutter, their arbors aren’t long enough to even install one.
View dbhost's profile
dbhost
5705 posts in 3200 days
#4 posted 03-03-2010 12:59 AM
Just out of curiosity, why is the depth difference between 6” and 8” dado sets of any interest?
I see this question asked a LOT on various forums and always wondered…
Are you going to try to do through cuts on 4×4 lumber with your stack dado set?
Am I missing something?
View richgreer's profile
richgreer
4541 posts in 3043 days
#5 posted 03-03-2010 01:08 AM
I have a slightly different twist on this subject. I have the Freud SD606 dado set. This is the 6” one with the dial-a-width feature. Because of the dial-a-width feature, my depth is limited to 1.25”. If I purchased the 8” version of the dado set, the depth could go to 2.25”
However, for me, I never need a dado depth greater than 1.25”. I have difficulty figuring out why anyone else would either.
View Andrew's profile
Andrew
709 posts in 3167 days
#6 posted 03-03-2010 01:24 AM
through dados? I have a 6” that I mounted on my bench top craftsman, could only cut about a 1/2 wide, so it did save a little time, except that it would trip the onboard circuit breaker (craftsman tools sometimes have that) I didn’t even think about touching the little red button until I had it all apart and was ready to take it in for service. I have heard that the 8” dados leave cleaner cuts. Good luck
-- Even a broken clock is right twice a day, unless, it moves at half speed like ....-As the Saw Turns
View 559dustdesigns's profile
559dustdesigns
633 posts in 3136 days
#7 posted 03-03-2010 01:26 AM
BreakingBoardom, I’ve got an Amana Tool 8” stack dado set model #658030. I really like this set the out side blades have 24 tpi.Its came with the shims with it. I guess the Forrest set would be better. But this set does everything I need. I’d get the best thing I could afford. I used to have a cheap Craftsman 8” set about 7 years ago when I first got in to making dust. This set is my friend’s at the moment he got it when he bought a used Jet saw. It came from Ideal saw works of Fresno, originally. It was brand new and I’ve been the only one to use it. I have been twisting his arm to trade me something for it. Hopefully it will soon become my own.
As for 8” vs 6” not sure I have ever needed to cut the full deep with the 8” set but I’ve never used a 6” inch set before. Probably you could measure from the center of your saws arbor to the table with the arbor all the way up to calculate approximately how deep you could get out of a 6” vs an 8” blade. The deepest I’ve cut with this set was about 1” with two passes (cut on the table legs of a resent project). For most operations a dado in a panel is only at most 3/8” deep, which can be done with a 6” for sure. On a small saw, a guy might consider the smaller set. Seams like it would be easier on the saw to turn less blade. Hope this is helpful as this is just just my opinion.
-- Aaron - central California "If you haven't got the time to do it right, when will you find the time to do it over?"
View Steve Peterson's profile
Steve Peterson
371 posts in 3051 days
#8 posted 03-03-2010 01:52 AM
I use a dado on my RAS to notch 2×4s for building workbench frames. The depth of cut is often 1.5” or even 2”. It is much easier to hog out the wood at one machine rather than set the depth to cut one side, then change the cut depth to make another cut at 90 degrees, or use chisels to clean up the notch. The RAS also allows fine tuning the depth of cut by turning the handle a small amount.
I can imagine exceeding the limits of a 6” dado.
-- Steve
View Gofor's profile
Gofor
470 posts in 3755 days
#9 posted 03-03-2010 02:58 AM
If you have the power to turn it, an 8” has more speed at which the tooth strikes the wood. This means you may get a smoother cut at the same feed rate. However, a more expensive set 6” with 4 tooth chippers will be better than an 8” with 2 tooth chippers. I, too, use mine to notch heavier lumber, so am glad I have the 8” and the extra 1” depth of cut.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
View marcb's profile
marcb
768 posts in 3642 days
#10 posted 03-03-2010 03:32 AM
Even when you’re not going into thick lumber if you have a 6 on a saw with a slightly limited depth of cut to begin with then use 3/4” plywood to build a jig you’re scraping by with 1/2” of depth so you can’t finger joint thick boxes/drawers/etc.
Not the worst downside, but I’ve seen it bite someone.
View cliffton's profile
cliffton
117 posts in 3050 days
#11 posted 03-03-2010 03:42 AM
if you ever use a sled to make your cuts you will appreciate the 8” dado.
View PineMan's profile
PineMan
71 posts in 3563 days
#12 posted 03-03-2010 04:56 AM
It all depends on how deep is the deepest a dado you want.
-- I never started a project I couldn't screw up.
View knotscott's profile
knotscott
7982 posts in 3344 days
#13 posted 03-03-2010 05:40 AM
The difference in price between the two sizes is often minimal, but the selection is much greater for the 8 inchers, which improves your odds of finding a great deal. If cost is the driving factor, IMHO you’d be better off using a router than the cheapest dado set you can find.
The extra height capacity is rarely used but can be handy, especially if you were to use a crosscut sled that eats into that capacity. There has been one time that I’ve need a very deep groove and actually ganged 3 ten inch blades together.
Rockler recently had the Oshlun 8” on sale for $60 shipped, which was actually cheaper than the 6” version….I haven’t tried this set but it’s getting good reviews for very good performance and excellent value. The DeWalt/Delta 7670 has been on sale from Grizzly for ~ $90…excellent deal IMHO. The Infinity Dadonator is the cat’s meow….@ $180 it’s not cheap but is very tough to beat.
BreakingBoardom
#14 posted 03-03-2010 05:58 PM
Yeah, I saw that Oshlun set on sale and that’s the one I was leaning towards. It’s not on sale at Rockler anymore , but still cheaper and seems to be a good set as per reviews. And I do intend on using sleds on occasion so the 8” may be the better option. Thanks for all the comments. I’ll probably end up going with an 8” version so I won’t have to worry about if I’ll have enough depth. Hopefully I won’t need to gang together 10” blades like knottscott. lol.
View 8iowa's profile
8iowa
1580 posts in 3730 days
#15 posted 03-03-2010 06:13 PM
Matt:
I have the 6” Oshlun set and it cuts beautiful dados for me. If your saw is designed to run on a standard 120V, 15 amp recepticle, then it is considered “underpowered” by the blade manufacturers. With this type of saw, the 6” dado set gives you greater cutting torque at the teeth, and makes it possible to do deep and wide dados without stalling the saw or tripping breakers.
For the more powerful saw, like 3 to 5 HP the 8” set would be preferred.
