What size cutters for carbide lathe tools?
« back to Woodturning forum
Forum topic by SuperCubber posted 03-13-2016 09:02 PM 755 views 1 time favorited 12 replies Add to Favorites Watch
View SuperCubber's profile
SuperCubber
1016 posts in 2194 days
03-13-2016 09:02 PM
Topic tags/keywords: carbide lathe tools carbide cutters
For you folks using carbide lathe tools, which cutter sizes for square, diamond and circle do you find most useful? It would be great to have various sizes, but I’m looking to start with one of each type. Also, what is the advantage to a radius square cutter vs. a square cutter?
I think I’ll use them for a combination of spindle and small bowl turning.
For what it’s worth, here is what I am planning on ordering:
13mm round
12 mm square
10×20mm diamond
Thanks,
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
12 replies so far
View TheDane's profile
TheDane
5367 posts in 3572 days
#1 posted 03-13-2016 09:27 PM
Radius square cutters are less likely to dig in … you can cut on the radius as well as the corner.
SuperCubber
#2 posted 03-13-2016 11:13 PM
Thanks, Gerry. Wouldn’t it be pretty difficult to cut a tenon with a radius though? I’m not opposed to getting both, and I probably will. I’m just trying to understand all the pros/cons.
TheDane
#3 posted 03-14-2016 12:38 AM
Probably … but I am an HSS guy anyway, so I have never tried doing a tenon with carbide tools. All I have ever used my carbides for was roughing, and haven’t even done that since last summer when I learned how to do Ellsworth’s roughing and shearing cuts.
View Woodknack's profile
Woodknack
11150 posts in 2290 days
#4 posted 03-14-2016 02:11 AM
How I use mine—
Square: great for roughing abrasive or very hard woods, good for squaring off ends or making long flats. Slower than a roughing gouge.
Diamond: I use this for finding centers and in combination with parting tools in very hard or abrasive woods, also sometimes in starting beads.
Radius: Cuts a little faster than square but is prone to catching, especially if you plunge.
Round: Marginally useful for coves in very hard or abrasive woods. I sometimes use this for removing bark.
I don’t think the size matters except match it to your tool size. So you don’t want a 5/8” cutter on a 3/8” bar. I order my cutters from AZCarbide.com and have been very pleased all around.
-- http://thewoodknack.blogspot.com/
SuperCubber
#5 posted 03-14-2016 02:22 AM
Thanks, Rick. That’s actually where I’m ordering them from. Glad to hear you’re happy with them.
I was planning on using 1/2” bar for all of them and tapering the end if/as necessary. Do you think that’s a reasonable plan?
SuperCubber
#6 posted 03-14-2016 02:44 AM
In case anyone else comes along looking for this info, I just found this nice comparison guide at azcarbide.com. This answers my question about the sizing pretty well.
http://azcarbide.com/wp-content/uploads/2015/05/Insert-Cross-Ref-Chart.pdf
Woodknack
#7 posted 03-14-2016 03:53 AM
Thanks, Rick. That s actually where I m ordering them from. Glad to hear you re happy with them.
I was planning on using 1/2” bar for all of them and tapering the end if/as necessary. Do you think that s a reasonable plan?
- SuperCubber
That should work fine. Last time I ordered it was late on a Friday, got a ship notification Saturday morning and had them in hand by Tuesday I think.
You might consider one of the Hunter round cup carbides. I’ve never used one but I imagine them as more useful than flat round.
http://azcarbide.com/product/8mm-round-carbide-shear-insert-for-wood-fits-hunter-2-tool/
View JoeinGa's profile
JoeinGa
7733 posts in 1916 days
#8 posted 03-14-2016 08:42 PM
I just got my first order from AZ. Ordered online last Friday, they we in my mailbox today.
I made my own tools using 5/8” aluminum barstock. I narrow the tips down and had been using the 14mm cutters up till now. This time I ordered the 15mm cutters.
SuperCubber
#9 posted 03-14-2016 08:54 PM
Thanks, Joe. I saw your post with the aluminum bar stock. Those were some pretty tools!
Woodknack
#10 posted 03-14-2016 09:00 PM
- JoeinGa
How is the aluminum holding up sliding against the steel tool rest? That was the only thing that held me back from using AL, fear a groove would wear into them.
JoeinGa
#11 posted 03-15-2016 12:33 AM
- JoeinGa
- Rick M.
Actually holding up very well Rick. No real big digs or gouging, just getting pretty marred up and scratched, but they slide back and forth just fine. I’ll try to remember to get a pic to show.
View hairy's profile
hairy
2610 posts in 3442 days
#12 posted 03-15-2016 12:49 AM
My go to tool for tenons is a square, not radius square. I make sure to cut only 1 surface at a time, bad things can happen, at least to me. A 1” skew flat on it’s side works pretty good,too.
-- My reality check bounced...
