| Forum topic by somewoodwork12 | posted 1173 days ago | 2679 views | 0 times favorited | 20 replies | ![]() |
1173 days ago |
Topic tags/keywords: question carving modern oak maple arts and crafts soap dish grooving surface routing sanding I have a question, im going to link two picture below of a soap dish and I want to know how is the soap dish surface groove made on it, what tool was used to make it, I would appreciate your insight. If the link doesn’t open the question is just about an oval surface groove on top of any soap dish, so the soap stays inside the dish. Thanks http://www.southerncrafter.com/Wooden%20Dish%20Oval%20New.jpg http://soappotions.com/images/roundsoapdish.jpg |
20 replies so far
#1 posted 1173 days ago |
I’ve never done this before but I’m thinking : cut out a template with your scroll saw and use a template guide (p 193 in the lee valley catalog top of page) on your router with a dish carving bit ( p 184 lee valley catalog bottom of page) I’m watching this to see if I’m right or if there is a better (easier way) to do this -- Simple advice is the best advice |
#2 posted 1173 days ago |
I second the template/router method, thats how people make the chip n dip trays, which is pretty much the same thing just on a different scale -- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves. |
#3 posted 1173 days ago |
Kodiak and Jei’son I know that method, and that way will only give you a straight bottom, the pictures show a curved bottom with the middle part being the most shallow portion and the edges less shallow, but thanks for the try guys :) |
#4 posted 1173 days ago |
I guess it can be done either on lathe or with a router using a template with dish cutter bit & also crown molding bit. Template : Dish cutter bit I’m sure other fellow LJs have better idea. -- masrol, kuala lumpur, MY. |
#5 posted 1173 days ago |
woodwormthe the crown molding bit is not the right tool for it because the biggest bit comes in 2.75 or 3 inches, I need a wider cut, and plus I don’t think thats the correct way, there must be another way they do this, because I’ve seen huge soap dishes that have this cut, Please try again |
#6 posted 1173 days ago |
I think for the round shape one is easy to be done on lathe, but the oblong shape one surely cannot. -- masrol, kuala lumpur, MY. |
#7 posted 1173 days ago |
woodworm yes the round shape one would be easy on a lathe, but what I’m trying to figure out is how they did the oval one, and when we figure that out we can do any shape we want basically. Im sure the correct way to do this is not on a lathe, there must be an easier and a more simpler way. Thanks |
#8 posted 1173 days ago |
CNC? Or is it specifically handmade? -- Ron -- Bear, DE |
#9 posted 1173 days ago |
In a production type setting, the oval dishes (and round for that matter) would have been done on a CNC Router with a cutter similar to the crown molding bit. -- Come to the dark side....we have cookies... |
#10 posted 1173 days ago |
If you are only making one or even a couple, I would think using a router to hog out most of the waste and then a carving gouge to refine the shape should make short work of this project. Here is a link to a spoon carving site which is similar to what you would be doing HERE -- Chips and Shavings/ see you at WWW.underconstructionlive.com |
#11 posted 1173 days ago |
I think a core box router bit and a template may be better then a dish carving bit because of the greater radius dimensions available. Maybe a core box for the inside edges and a dish carving for the bottom? http://www.rockler.com/product.cfm?page=2121&tagem=rv -- Mark, www.mrhudon.com |
#12 posted 1172 days ago |
Thinking WAY outside the box- imagine cutting the soap dish in half across the dish. The profile revealed is a big scoop with a flat on each side. If you made a knife in that profile and put it in a cutterhead- a plunge cut would make the round soap dish while advancing the piece or the cutterhead while in the cut would make the oval shape. I would think this would be extremely dangerous for kickback unless you could use a long board and put a series of plunge cuts in the length while antikickback fingers and feed rolls held the piece tight. Kind of thinking a moulder running an S4S with a seperate adjustable head doing the plunge as the feed was periodically stopped. Or a cutterhead for rosettes could be made in the same shape and put in a drill press or overhead router and plunge cut for the round and moved sideways for the oval. Also potentially very dangerous. Not recommending either option, just putting the concept out there. |
#13 posted 1172 days ago |
Actually there is such a lathe called an Elliptical lathe It can also be done on a table saw or radial arm saw. Round is easy and the oval just takes a bit of fixturing. Think cove cutting on a table saw but you aren’t running a long piece, just a short piece with stops. It can also be done with a router rigged up on multi-axis pivots and slides. One could also make a master form and do it with a carving machine. These concepts are not speculation but based on actual experience of myself and other folks I know as well as classic text book examples. -- Few folks really know how to maximize the potential of their tools! |
#14 posted 1172 days ago |
Try making a router sled. Use curved side rails to match the curve of the inside of the dish. Try this link http://lumberjocks.com/topics/45 much smaller scale , of course. -- Karen - a little bit of stupid goes a long way |
#15 posted 1172 days ago |
Thanks for all the input guys, but after some thought and prior condemnation of woodworms theory I think woodworm got it right, it was a method mentioned here by him but with a twist, get it “a twist” :D (clears throat) ok moving on…. with a little emphasize on the horizontal crown molding bit, you would have to make a template in this case an oval one, but instead of using a bowl bit which would have given you a flat bottom, you use a crown molding bit :) which will give you that curved bottom, problem solved im going to make one soon and will post my pictures up. Thanks for all the help guys God Bless and visit my website www.thewordthetruth.com Jesus Christ’s return is close at hand, repent and give yourself to Christ before its too late |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15748 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
