Zero Clearance Inserts and Height Adjustment
Forum topic by IowaWoodcrafter posted 733 days ago 281 views 0 times favorited 10 replies Add to Favorites Watch
Rockler
View IowaWoodcrafter's profile
IowaWoodcrafter
256 posts in 976 days
733 days ago
Topic tags/keywords: set screw zero clearance insert
Last night I made a couple zero clearance inserts for my table saw. This is the first time I’ve ever had any. I used 1/2” baltic birch plywood with counter top style laminate. The inserts weren’t quite tall enough so I removed the set screws used to adjust the height from the standard insert. I drilled four holes in the insert and screwed in the set screws. This worked like a charm, but then I realized I might need to use the standard insert. I also want to make several inserts for various size dado widths.
So, the problem I realized was that I needed some more set screws. I emailed Grizzly to find out how much they would be. They responded and said $1 each, which seemed pretty high to me. The best part though was that they sent me the specifications for the screws 1/4” Diameter, 20 TPI x 1/2” Length. So, I do a Google search and find a company that sells this type of set screws for $2.50 per box of 100. I happily begin to place my order and found out that shipping was going to be $5.00. So, I increased the order to two boxes, still $5.00 for shipping. So now I’ve got 200 set screws coming that cost me roughly 6 cents each. If anybody is looking for some set screws check out Jordan Industrial Supply. If you don’t want to order 200 send me a message and I’ll send you some cheap.
-- Owen Johnson - aka IowaWoodcrafter
View Blake's profile
Blake
2763 posts in 774 days
733 days ago
I appreciate the offer… but did you check your local hardware store? I had to buy some for my router plate last week and they are readily available and cheap (at least in my area).
View Sawdust2's profile
Sawdust2
1190 posts in 987 days
732 days ago
But this way he can have 50 zero insert plates.
I’m a lot stingier. I use pine, not good Baltic birch.
View alanealane's profile
alanealane
174 posts in 790 days
732 days ago
If you can find a market for selling those screws @ the Grizzly price….WELL THEN!!! You could go on vacation a lot more often. ;-D
-- Lane Custom Guitars and Basses
View Thos. Angle's profile
Thos. Angle
4013 posts in 862 days
732 days ago
Let me see if I got this right; you didn’t want to spend $4 so you spent $7.50 and now have 196 screws left over? LOL That’s the American way. I’m laughing with you, pardner, I do it too.
-- Thos. Angle
View SPalm's profile
SPalm
951 posts in 782 days
732 days ago
We loose money on every product we sell, but make up for it on volume.
I’ll keep your offer in mind,
Steve
Blake
732 days ago
Zero clearance inserts are a good idea in general. I found the hardwood ones that I would make tended to warp, cup or sag over time. I now use the (Phlemonic? Phlomonic? Phelmonic? Phlobotomy? Phelmonic?) ...plastic ones.
IowaWoodcrafter
732 days ago
Thos.
I want to have about 8 inserts in the following formats…
1 for the blade set at the standard 90 degrees
1 for the blade set at 45 degrees
1 for a dado set to 3/4”
1 for a dado set to 1/2”
1 for a dado set to 1/4”
Dado’s set for standard plywood thicknesses, (so three more there).
That would have been $32 plus shipping. I think I saved some money doing it this way.
View Mark Mazzo's profile
Mark Mazzo
343 posts in 812 days
732 days ago
I typically just use duct/masking tape to level my zero-clearance inserts. Cheap and effective if there is only a little bit of adjustment to do.
Hey Blake: That’s Phenolic ;-) I just use 1/2” MDF, seems to be very stable.
View GaryK's profile
GaryK
9555 posts in 888 days
732 days ago
I use 1/2 cabinet grade plywood and make about 5-7 at a time. Then I glue a thin piece of wood in each
corner thicker than needed. Then I run them all through my drum sander to sand down the pieces of wood until they are the right thickness to make the plate sit flush with my top.
Never any adjustment needed after that.
Thos. Angle
732 days ago
You did good. Just pulling your leg.
-- Thos. Angle
