Help Me Win a Bet with Son-in-Law
Forum topic by docspencer posted 03-12-2016 10:30 PM 1293 views 0 times favorited 10 replies Add to Favorites Watch
View docspencer's profile
docspencer
378 posts in 2184 days
03-12-2016 10:30 PM
My son-in-law found some walnut lumber in his mom’s house – in the crawlspace. He’s excited – as well he should be. He thinks its as dry as its going to get. BTW – he says it was milled 10 years ago. I told him it’s probably not dry enough yet – that he should take it home and store it in his shed where it’s drier and has air movement. There’s a six pack of good beer on the line. Which one of us right?
10 replies so far
View bigblockyeti's profile
bigblockyeti
5317 posts in 1959 days
#1 posted 03-12-2016 10:51 PM
Depends on the average humidity in the crawlspace, what if any air movement there was and how thick the wood was cut. Also depends on whether or not it was stacked properly and stickered.
View bearkatwood's profile
bearkatwood
1679 posts in 1250 days
#2 posted 03-12-2016 11:02 PM
I agree, it is based on the RH of the two spaces, so if the crawl space is damp (which they usually are even with a good vapor barrier) and the shop is dry, your in the money or brewski.
-- Brian Noel
View MadMark's profile
MadMark
979 posts in 1692 days
#3 posted 03-12-2016 11:03 PM
Average dry time is 1 yr per inch. 10 yrs is plenty for drying all but rail timbers. If you want to be sure invest in a pin moisture meter:
Walnut is a lighter/softer wood and will dry relatively quickly. Buy him his favorite brew.
M
View AlaskaGuy's profile (online now)
AlaskaGuy
4996 posts in 2548 days
#4 posted 03-13-2016 12:12 AM
The one year per inch is just a rule of thumb and that all it is.
Lumber will only dry to the place it lives. If it lives in Arizona the MC will be much less that if it lives in Florida where the RH is higher.
Like someone said it depends on the RH of the location of the lumber. If the RH changes so does the MC of the wood.
I wouldn’t buy any coffee just yet.
Mark, wood is like a sponge it’s always taking in or giving off moisture depending on the changes in the RH.
AlaskaGuy
#5 posted 03-13-2016 12:13 AM
- bearkatwood
+1 this is the way it works.
AlaskaGuy
#6 posted 03-13-2016 12:27 AM
M
- MadMark
As usual Rockler is to high on there prices. I’d buy the moister at HD for much less.
http://www.homedepot.com/p/General-Tools-Pin-Type-Digital-Moisture-Meter-with-LCD-Display-MMD4E/100651808?cm_mmc=Shopping|THD|G|0|G-BASE-PLA-D25T-HandTools|&gclid=CIaOneKzvMsCFQdqfgodL9IIzw&gclsrc=aw.ds
View wood2woodknot's profile
wood2woodknot
97 posts in 2212 days
#7 posted 03-13-2016 01:05 AM
I would say the ultimate question is has it reached an equilibrium …............ equal to the working RH of his shop …...... and how different is that from the terminal location of the finished product?
-- ajh
View WDHLT15's profile
WDHLT15
1797 posts in 2715 days
#8 posted 03-13-2016 01:38 AM
Doc,
A crawl space is not climate controlled. You are right. Enjoy your brew.
View LiveEdge's profile
LiveEdge
598 posts in 1859 days
#9 posted 03-13-2016 05:47 PM
Why would the RH of a crawlspace be significantly different than the RH outside? It isn’t controlled and should have air vents for exchange. To me the wood has the equivalent of sitting outside for 10 years without getting rained on.
View tomsteve's profile
tomsteve
897 posts in 1458 days
#10 posted 03-13-2016 07:56 PM
ive been in both very dry and very humid crawl spaces. none of us have any idea how the conditions are in that crawl space. be best to get one of them moisture meters and find out what the mc is. best to cut an inch or 2 off an end and check. might even want to cut one in half to check.
