Debate Homemade V- vs. Thickness-Sander NO MORE!
Forum topic by Alan S posted 03-02-2010 03:20 AM 7307 views 10 times favorited 20 replies Add to Favorites Watch
View Alan S's profile
Alan S
181 posts in 3492 days
03-02-2010 03:20 AM
A thought occurred to me recently when trying to compare the V-drum type sanders to the homemade thickness sanders: why can’t I make a tool that is both? And here are some sketchup models showing what’s in my head:
Basically, there are two tables that use the sanding drum, one on top of the other. For those of you with dust collection setups (not me), I added a dust shroud in the middle that might collect some of the dust.
What do you guys think? Am I crazy? I won’t be able to build this any time soon, but it should be fairly cheap. All the frame members are 2×4s.
Alan
20 replies so far
View interpim's profile
interpim
1170 posts in 3633 days
#1 posted 03-02-2010 03:28 AM
I like the idea… i really should look into getting stuff together to make one of these.
-- San Diego, CA
View PaulfromVictor's profile
PaulfromVictor
228 posts in 3520 days
#2 posted 03-02-2010 03:29 AM
Interesting thought. I am also in the process of building a drum sander. I don’t understand what the benefit of the v drum is. I wish I had some experience to offer some insight. One thing I might do is increase the length of the outfeed table.
Alan S
#3 posted 03-02-2010 03:38 AM
The top section, the V-Drum sander (anyone know why it’s called “V”?) is similar to an abrasive jointer, whereas the bottom section is just like an abrasive planer.
Alan
PaulfromVictor
#4 posted 03-02-2010 03:44 AM
Are the infeed and outfeed tables offset as they would be on a jointer?
Alan S
#5 posted 03-02-2010 03:48 AM
PaulfromVictor, not that I know of. As I understand, the amount of wood taken off is even small than in a jointer. I’m not sure how they get away without offsetting the tables, but search lumberjocks for “sanding flee” or “v-drum sander” to see more about them.
Alan
View Jeison's profile
Jeison
968 posts in 3282 days
#6 posted 03-02-2010 04:07 AM
You sir get +1 smartypants point for this idea :D
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
View bigike's profile
bigike
4054 posts in 3463 days
#7 posted 03-02-2010 04:23 AM
it’ll work with no problem, biggest hassel is going to be the build if your like me.
13635 posts in 3516 days
#8 posted 03-02-2010 04:35 AM
this is nice ,
the biggest problem i think ,
is raising and lowering the ’ planer ’ table .
on the outfeed side ,
have some holes for a pipe at stagered heights ,
and a notch in the framed table to ride and stop on the pipe .
the front can be raised or lowered by wedge or screw mechanism .
117276 posts in 3752 days
#9 posted 03-02-2010 04:37 AM
Cool idea
View JimNEB's profile
JimNEB
239 posts in 3243 days
#10 posted 03-02-2010 04:47 AM
I’d be a little nervous about on the planer part that it would grab the piece and shoot it out the other side…
-- Jim, Nebraska
#11 posted 03-02-2010 05:00 AM
jim ,
you feed it agains the rotatoin ,
just like a regular planer ,
you do light passes ,
and push it through .
teenagewoodworker
2727 posts in 3943 days
#12 posted 03-02-2010 05:26 AM
only problem i can think of is the dust collection… its not just for show on drum sanders the dust collection helps to stop the paper from clogging up which can prevent burns and all that nasty stuff…. you’ve defidently got a winner there are far as the idea goes but i would say see what you can do about some dust collection.
View GFYS's profile
GFYS
711 posts in 3646 days
#13 posted 03-02-2010 06:42 AM
My understanding of the sand flea type v drum sander is that the abrasive is attached to the drum with hook and loop velcro which allows the abrasive to raise up and give some flexibility contacting the workpiece. The drum and abrasive actually sits lower than the work surface untill the centrifical force of the spinning drum makes the abrasive raise up to contact the work piece. A thickness sander being a more rigid/solid sanding surface is not likely to work well with abrasive loosely fixed to the drum like that.
Don’t mean to rain on your parade.
View Broglea's profile
Broglea
685 posts in 3265 days
#14 posted 03-02-2010 06:43 AM
What type of sandpaper will you use? PSA or H&L? The reason I ask is the V drum sander will only work with H&L. If you are planning on using H&L for the thickness sander too there shouldn’t be any problem with your plan. I don’t have a thickness sander so I’m not sure if H&L can be used with it.
Alan S
#15 posted 03-02-2010 03:23 PM
Dan, I guess the worst thing I would have to do is have two different drums that could be interchanged. I’ll have to think about that some more. Thanks for the constructive criticism. That’s one reason I put it up here: so I could see what holes people shoot in it and how to mitigate those problems. Thanks!
Alan
