Best way to remove saw marks after resawing on the bandsaw?
Forum topic by Jack Gaskins posted 03-02-2010 03:07 AM 8384 views 0 times favorited 15 replies Add to Favorites Watch
View Jack Gaskins's profile
Jack Gaskins
46 posts in 3008 days
03-02-2010 03:07 AM
I want to resaw some 1/8” strips off of a 3/4” boards board. I do not have a planer or a drum sander or any sander for that matter (well except for an ROS). Should I purchase a planer to remove the marks or an edge sander? I would say a drum sander but I think I would get more from an edge sander? Thoughts. I am just a hobbiest woodworker/woodturner. I ALMOST had a planer I purchsed from a guy in New York but that is a different RANT/post.
-- USAF Ret. 2006
15 replies so far
View richgreer's profile
richgreer
4541 posts in 3068 days
#1 posted 03-02-2010 03:26 AM
I have seen resawing that is almost perfectly smooth right off the band saw but that is very rare (at least in my shop). I really think you need to plan on passing resawed wood through a thickness planner. In theory, you could do it with a drum sander but that would take a lot more passes and use up a lot of sanding material.
Once you have is smoothed with a thickness planer, your ROS will finish the job for you.
As an FYI, I usually resaw my wood about a 1/16th of an inch thicker than what I will eventually need and I plan on the thickness planer taking bringing the wood back to the desired thickness.
View GaryK's profile
GaryK
10262 posts in 3982 days
#2 posted 03-02-2010 03:39 AM
If you need it to be a consistent thickness, then either a planer or drum sander.
If you really want to take a slow boat, then double stick tape it to a nice square parallel board and run it through the table saw. But if you are going to do that why not just cut them on the table saw in the first place.
Jack Gaskins
#3 posted 03-02-2010 03:51 AM
Well I am using the thin strips for laminating in glue ups so I just wanted to make sure the surfases were flat enough for glue ups and then the laminations will be used for gluing to turning blanks and for making woodturned braclets. I dont have a planer or drum sander. I was actually wanting to get an edge sanding machine, could probably make a jig for running the thin boards over it?? I thought I had a new planer coming in the mail but the seller screwed me, see the coffee lounge for my rant on that scumbag,,,,
-- USAF Ret. 2006
View EricRFP's profile
EricRFP
106 posts in 3088 days
#4 posted 03-02-2010 03:58 AM
My #1 tip. Buy a re-saw blade and if that doesn’t do it, buy a better re-saw blade. If needed you may also need to upgrade you guides. My re-saw bandsaw leaves almost no marks at all, maybe a 100th.
-- Eric, NorCal www.rocklinforestproducts.com
View bigike's profile
bigike
4052 posts in 3282 days
#5 posted 03-02-2010 04:21 AM
a freshly sharpend hand plane should do the trick.
View russv's profile
russv
262 posts in 3163 days
#6 posted 03-02-2010 04:49 AM
sounds like a jointer would work best. you can set up to joint edges on your router table if you have one.
russv
-- yknotwood.com: where to go because you don't want no stinking plastic!
View Alex Lane's profile
Alex Lane
508 posts in 3884 days
#7 posted 03-02-2010 06:41 AM
Jack, if I understand correctly, you want to RIP strips from a 3/4” thick board, not resaw. I consider resawing a cut taken parallel to the broad face of the board. I think you’re seeking to rip pieces of wood 1/8” thick x 3/4” wide x whatever length, right?
If so, there is a product that can turn your drill press into a small planer. It’s sold by Woodworker’s Supply and other suppliers.
Drill Press Planer
See it here.
Hooray, a $25 mini-planer!! But, if anyone has had experience with this drill press planer and found it to be a bad product, please let us all know. I’ve never used one, but it always looked intriguing in the woodworking catalog.
You might want to come up with a simple jig to make sure the wood strips don’t raise up from the drill press table while you run them past the cutter. Maybe a featherboard would work…
I agree with richgreer in his comment above when he said “As an FYI, I usually resaw my wood about a 1/16th of an inch thicker than what I will eventually need and I plan on the thickness planer taking bringing the wood back to the desired thickness.”
I hope this helps!!
-- Lane Custom Guitars and Basses
View bladeburner's profile
bladeburner
88 posts in 3081 days
#8 posted 03-02-2010 04:38 PM
Sounds like you’re looking for a thin piece ripping jig. With a good blade I don’t need any cleanup with this jig.
http://www.ncwoodworker.net/pp/data/1419/Spline_Jig_8_.JPG
Alex Lane
#9 posted 03-02-2010 04:44 PM
Good one bladeburner!! I forgot about using a thin-ripping jig on the TS. Here's a project by LumberJock niki on making a jig to rip narrow pieces.
View Sawkerf's profile
Sawkerf
1730 posts in 3062 days
#10 posted 03-02-2010 05:48 PM
I would rip 3/16” – 1/4” strips on my TS, then run those thru the planer to get to 1/8”. Planing something that thin can sometimes be a problem, though.
Jack Gaskins
#11 posted 03-02-2010 10:37 PM
Sorry but I didnt say anything about “ripping” I said “strips” like you get when you resaw on a bandsaw.
-- USAF Ret. 2006
Alex Lane
#12 posted 03-02-2010 11:30 PM
Jack, sorry we misunderstood. What are the final dimensions you hope to get from these “strips”? ——————-1/8” thick x what width?
I’m still confused as to which way the cut is being made. In my feeble mind…LOL…I find the words “resaw” and “strips” to be unrelated, but we must be having a difference of woodworking terms.
So you are indeed resawing a 3/4” wide board into what I’d call “thick veneers”?
Sorry about all the confusion… ;-D
What do you think of that Drill Press Planer mentioned above? Might it work for your resawing?
View hairy's profile
hairy
2701 posts in 3526 days
#13 posted 03-03-2010 12:21 AM
1 more vote for the tablesaw, if thickness is not an issue. There is a special saw blade for what you want to do.
http://www.amazon.com/Freud-LM75R010-10-Inch-8-Inch-Arbor/dp/B001V5J4QY
-- My reality check bounced...
View HokieMojo's profile
HokieMojo
2104 posts in 3722 days
#14 posted 03-03-2010 12:53 AM
i think of resawing as producing thin sheets, not strips. I think that is why everyone is confused.
Jack Gaskins
#15 posted 03-03-2010 02:04 AM
Yes, sorry, THIN SHEETS 1/8” thin.
-- USAF Ret. 2006
