Best material for DIY temporary paint booth walls?
Forum topic by golden478 posted 03-12-2016 07:37 AM 1757 views 0 times favorited 6 replies Add to Favorites Watch
View golden478's profile
golden478
7 posts in 867 days
03-12-2016 07:37 AM
Topic tags/keywords: finishing question spray gun paint booth
Hi all,
I am spraying a water-based clear finish on lots of small wood tabletops. I hung cheap clear tarps (made of polyethylene) to protect the walls while I worked on my project, but the dried overspray flaked off everywhere the next day, which will easily become airborne and ruin the finish as I continue spraying on the clear finish.
In hindsight, I feel I should have seen this problem coming, since clear tarps are meant to protect and repel against fluids.
Is there a better material that the water-based finish will actually stick to without flaking off?
I plan to test similarly cheap, disposable materials like cardboard or canvas (since both are porous and more absorbent) as an alternative to the plastic tarps.
Any solutions, thoughts or ideas are welcome. TIA.
View JoeinGa's profile
JoeinGa
7736 posts in 2003 days
#1 posted 03-12-2016 12:54 PM
Bed sheets.
While not see-thru, the white ones will help reflect light while you work.
They’re flexible enough to make them into “roll-up” using closet dowels if you like.
They’ll absorb the air-born stuff, and best of all you can sometimes buy them for really cheap at Goodwill or Salvation Army stores.
View Kelly's profile
Kelly
2025 posts in 2940 days
#2 posted 03-12-2016 04:05 PM
Just hit a big box and pick up some canvas painters tarps. If need be, get a big one and cut it to size.
4984 posts in 2489 days
#3 posted 03-12-2016 05:00 PM
The bed sheets idea appeals to me, since the thrift stores may have them really cheap.
View AlaskaGuy's profile
AlaskaGuy
4127 posts in 2305 days
#4 posted 03-12-2016 05:17 PM
I don’t know what to tell you. I’ve had good success with hanging plastic sheeting for a temporary area area. I do have a fan that blow some of the over spray out side.
Do you have any fan set up to blow outside or to suck some of the over-spray through a filter?
View OSU55's profile
OSU55
1666 posts in 1985 days
#5 posted 03-12-2016 05:46 PM
I use plastic sheets. I used them to make “Roman blinds” that I roll up to the ceiling when not in use. I spray a lot of waterborne, and don’t have the issue you described, but I use a 110V 800 cfm squirrel cage blower with 2 filters which creates flow in the booth and pulls in the overspray. I turn it on for 20-30 minutes before I spray to clear out the air. Here is a pic with them rolled up. Can’t find the one with them down. I also have 2×2’s hung from the ceiling that I can hang parts on to dry. I have a hook hanging from the ceiling in front of the blower (the 2×4 sticking down) to hang parts on to spray, then move them to the 2×2’s. I also have lazy susans that sit on buckets or whatever to sit in front of the blower.
View retfr8flyr's profile
retfr8flyr
384 posts in 1665 days
#6 posted 03-13-2016 05:15 AM
I use drop cloths from Lowes for my spray booth and put it up and take it down when needed.
-- Earl
